mesa 7i76e vfd spindle speed problem
5 years 1 month ago #219546
To further elaborate..
For a _lathe_ you absolutely need the index to happen exactly once per spindle revolution to allow single-point threading to work.
But, having checked with the mailing list, you can rigid-tap on a mill with an index that is not synchronised to the spindle, just as long as the spindle encoder scaling takes in to consideration the gear ratio _and_ as long as you never try to do more than one rigid-tapping operation in the same hole.
Replied by andypugh on topic mesa 7i76e vfd spindle speed problem
Wait a moment the encoder is channel A , channel B and channel I ( index connected to the encoder index input in the TB4 mesa 7i76e card)
- Raban
5 years 1 month ago #219556
by Raban
Replied by Raban on topic mesa 7i76e vfd spindle speed problem
G33.1 rigid tapping tested and work !
Time to create page: 0.564 seconds
