IHSS57-36 with 7i92 don't move
- markusk
30 Sep 2021 23:37 #221926
by markusk
Replied by markusk on topic IHSS57-36 with 7i92 don't move
oh, wait.
could someone please clarify what 'with pin1s connected' means?Note: 26 pin header P1 will match standard parallel port pin-out if terminated with flat cable 26 pin receptacle/DB25F cable with pin1s connected (and header pin 26 left open)
- Thank you received: 5329
30 Sep 2021 23:58 #221928
Replied by PCW on topic IHSS57-36 with 7i92 don't move
DB25 pin 1 connects to HDR26 pin 1
01 Oct 2021 00:07 #221929
Most standard firmware duplicates the P2 pinout on P1 (but you would have to edit the hal file to change the stepgen and GPIO numbers)
Unfortunately, if you damaged a bus switch (U4 or U6 which typically bear the brunt of excess/reverse voltage damage) ,
it will affect both connectors. These are cheap chips but tricky to replace unless you are used to SMT repair.
my question still stands - is there a bit-file to be found that configures the P1 the same way as P2 is with the default firmware? am i assuming correctly that the P1's pins still all should work fine?
Time to create page: 0.069 seconds
