Cannot get stepper motors to move
4 years 8 months ago #233764 by Jalapeno56
I have struggling with this for several weeks now....
Even went so far as to send my board back for repair because no output on the board. (non-issue, board tested ok at Mesa)
Running Debian 11 5.10.0-11-rt-amd64
Linuxcnc 2.9
Mesa 7I76E
DM542 Drivers
23HS45-4204S 425 oz. steppers
I have followed Norberts connection sheet, Steppers have green lights and are locked.  ENB is not hooked up on drivers.  I have tried settings anywhere from 200 to 15000.
I have to be missing a setting or something somewhere.
I have included my hal and ini files also (I know they are far from complete, just trying to get something to move.)
Any help is much appreciated!
4 years 8 months ago #233765 by Jalapeno56
I apparently had too many thoughts at the same time while I typed the previous post...
*Stepper DRIVERS have green lights and steppers are locked*
Also, I am able to ping the board (@10.10.10.10) and see the firmware, so I know it is connected.
4 years 8 months ago #233777 by Clive S
How are you trying to mover the steppers ie are you trying to jog from the keyboard ?
When you use a - in HOME_SEQUENCE = -1 you have to home the machine first before it will jog
Also are you sure it is not moving as you have a very low HOME_SEARCH_VEL = -1.000000 = 1mm/min
4 years 8 months ago #233788 by Jalapeno56
I am trying to use the Test/Tune Axis button in pncConf to move the steppers. Changing settings in there as stated above and using the enable button and run or + -
4 years 8 months ago #233844 by Jalapeno56
I changed the homing requirement, no change. Changed homing velocity to 200, no change.
4 years 8 months ago #233846 by tommylight
Upload a picture of wiring here.
Time to create page: 0.160 seconds
