Problems whit the switches in pncconf
10 Feb 2022 19:27 #234520 by PCW
Replied by PCW on topic Problems whit the switches in pncconf
Can you post your hal and ini files?
  • Nest
  • Nest's Avatar Topic Author
  • Premium Member
  • Premium Member
10 Feb 2022 19:34 #234521 by Nest
Replied by Nest on topic Problems whit the switches in pncconf
Yes.....
File Name: CNC3040Z-DQ.hal
File Size:10 KB
File Name: CNC3040Z-DQ.ini
File Size:4 KB
10 Feb 2022 19:40 #234522 by PCW
Hmm, that does not match your halshow listing
  • Nest
  • Premium Member
  • Premium Member
10 Feb 2022 21:43 - 11 Feb 2022 13:49 #234530 by Nest
i fixed it... the problem was in the hardware switches... Do I need to install pull down resistors?
i had a bad configuration at now the machive work fine.
the next step i have to configure the spindle
Thansk you for the help, the halshow has helped me a lot
Last edit: 11 Feb 2022 13:49 by Nest.
Time to create page: 0.083 seconds
