- Thank you received: 216
That sounds all very simple Robert until I try it
then you start up the pncconf programme (to configure linuxcnc and these Mesa card to see each other and create the configuration files)
basically, start the pncconf and work your way through the dialogues and it will create the config files.
So I have ordered a "dongle " and I have an adaptor which permits connection of the lan cable from my router , into a USB port and am using that awaiting the dongle . . Still shows no internet connection and I suspect dongle will show the same , so how do I set up a connection so that I can download stuff onto linux machine .?get a cheap usb WiFi dongle for internet connection. the ethernet is much more important for dedicated regular CNC communication
