New install of Mesa 7i92 on TCL lathe
4 years 6 months ago #240875 by john11668
Thanks for that "linuxhint" too ALittleOffTheRails.
Will try to follow that one tonight when i get back to base .
4 years 6 months ago #240876 by tommylight
I have already(after earlier instructions ) edited the file /etc/network/interfaces .
OK, i have no idea how to revert back from that, although i would like to think that deleting the parts that were added should do the trick.
  • ALittleOffTheRails
  • New Member
  • New Member
4 years 6 months ago #240879 by ALittleOffTheRails
Replied by ALittleOffTheRails on topic New install of Mesa 7i92 on TCL lathe
Mint 19.2
# interfaces(5) file used by ifup(8) and ifdown(8) auto lo iface lo inet loopback
4 years 6 months ago #240894 by Clive S
Are you trying to get wifi working
I think you said you have bought a dongle, What did you get?
I gave a link in  forum.linuxcnc.org/39-pncconf/45604-new-...athe?start=20#240327
you would plug that into a usb port.
If I am off the mark just forget my post
4 years 6 months ago #240895 by john11668
What version of Mint, it's always good to know.
So would it be safe to assume that this "adapter" is a USB to LAN adapter ?
Yes
If you could supply as much info as possible regarding the USB to LAN adapter that would be great. It will help determining if a driver is available.
Prefably the output of the following.
sudo lsusb [color=#d35400]Result  Bus nos 001--005  Only the following looks promising      Bus 001  Device 002: ID Obda:8151 Realtek semiconductor corp. RTL8151 Adapteon Business Mobile Networks BV[/color] If the command is not found you will need to install usbutils: [code]sudo apt-get install usbutils [color=#d35400]Even after this I still get not found [/color] Once you get to a stage where you have more than one network adapter (this means any combination of Wifi\Ehernet or whatever) you need to tell the system how to configure each adapter, it does not know automagically how to do that. Just remember to keep your Mesa card and home network on different segments. ie Mesa may be on 10.10.10.xxx and your Home network on 192.168.1.xxx Only the home network with require the use of a Gateway & DNS server, the Mesa network requires neither. This is an article on how to setup a network using Mint. Now remember not to change the network settings for the network that connects to your MESA card. This may or may not pertain to your Version of Linux Mint. https://linuxhint.com/network-configuration-linux-mint/ Remember also that if you have a spare PCi\PCIe slot inside the computer you do not need to use a USB adapter, there is the option to use a appropriate internal network adapter
[/code]
My  system is Mint 19.3 tricia
Menu /  Network  brings up a single folder called windows network trying to open this
Leads to error message "Unable to mount location  , Failed  to retrieve share list from server   : no such file or directory,
4 years 6 months ago #240902 by john11668
I ordered this one Clive ,
2700Mbps Wireless USB WiFi Adapter Dongle LAN 802.11BGN 2.4/ 5.8Ghz 5G Dual Band | eBay
but still waiting for it to arrive  , so yesterday bought a lan adaptor to USB from local shop. Anything to get me going.
I just could not get going with no facility to download on this machine .
I presume I would still have to set up a connection even with dongle but as you can see from recent post  menu / network leads me nowhere.
I dont care what I have to do to connect to internet , but every prospect seems to lead me to a dead end
Time to create page: 0.159 seconds
