New install of Mesa 7i92 on TCL lathe
  • ALittleOffTheRails
  • New Member
  • New Member
4 years 6 months ago - 4 years 6 months ago #240993 by ALittleOffTheRails
Replied by ALittleOffTheRails on topic New install of Mesa 7i92 on TCL lathe
John you need to pay attention, for some reason you seem to be missing some steps.
I said before, forum.linuxcnc.org/39-pncconf/45604-new-...athe?start=60#240906 , you need to revert the /etc/network/interfaces file back to it original contents.
Now.
When you performed the ip a command and sudo dmesg | grep eth did you have your USB to LAN adapter plugged in ? It is helpful to have the adapter plugged in.
The hardware connection type will be an Ethernet connection.
Last edit: 4 years 6 months ago by ALittleOffTheRails.
4 years 6 months ago - 4 years 6 months ago #240999 by john11668
Now.
I saw that link but surely reverting  will delete the connection to the mesa card .
Are we going back to square 1 ??
And I am reading that link to say delete all except the first two lines . Is that what is intended ??
Lan was connected via the usb adaptor  and all was powered up.
So what are the steps to create a new connection using the ethernet option.
Last edit: 4 years 6 months ago by john11668.
4 years 6 months ago - 4 years 6 months ago #241002 by john11668
OK so did that!
Now outputs as follows :-
Forget the above    . mesa not powered up
Will repeat the process  after dinner
4 years 6 months ago #241013 by john11668
So trying again.
Reverted   /etc/network/interfaces , and with all connections powered up ,recorded the terminal outputs as follows:-
(hard work when you have to upload a photo,  download to second machine and resize for posting )
Then   menu / preferences/ network connections gives
So does that let us advance in some way please
4 years 6 months ago #241024 by tommylight
Looks OK, so go back to the link i posted and follow that tutorial for setting up the IPV4 stuff.
BTW, there is only one network card on that PC.
  • New Member
  • New Member
4 years 6 months ago #241035 by ALittleOffTheRails
It's not what he wants,
He wants the internal on board LAN for MESA and USB to LAN for his network.
The USB to LAN adapter is not showing up. For Mint you don't need to mess with the /etc/network/interfaces file. Don't touch it.
The OP is going to back to where he started.
Personally I think he needs to contact his local Linux Users group and ask if they can suggest someone to possibly come out on site to make a visit. It would appear he doesn't want to learn but just be given a tutorial.
Time to create page: 0.473 seconds
