New install of Mesa 7i92 on TCL lathe
4 years 6 months ago - 4 years 6 months ago #241200 by john11668
Works fine . I am responding from workshop windows PC (with it )
I disconnected the existing Lan cable from ethernet port , plugged the other cable (with lan to USB adaptor) into USB port And I have fine fast internet
Does this change any of the above ??
Last edit: 4 years 6 months ago by john11668.
  • ALittleOffTheRails
  • New Member
  • New Member
4 years 6 months ago - 4 years 6 months ago #241201 by ALittleOffTheRails
Replied by ALittleOffTheRails on topic New install of Mesa 7i92 on TCL lathe
The output of ip a would be interesting.
Or, which is better as it shows all devices with MAC & driver.
inxi -n
inxi can be installed via
sudo inxi -n
So how did you get it to show up ? Did it need tweaking, just asking as in your previous posts it didn't show itself.
If it's working you can swap the jumpers on the 7i92 to change to the 10.10.10.xxx setiing, I'm pretty sure PCW mentioned it earlier, or you can read the manual. Remember the 7i92 needs to go through a power cycle. Then you can setup the internal adapter, as shown in my previous post before. Remember the PC must have last 3 digits different to the 7i92. Just in case you've forgotten, hopefully you didn't.
Last edit: 4 years 6 months ago by ALittleOffTheRails.
4 years 6 months ago #241211 by john11668
So  things have changed a bit.
Found and fitted a wifi dongle i forgot I had and connectec it using the wifi function at the RH end of the menu bar .
Installed inxi -n and looked at ip a (after a restart)
So here are results of a screenshot on this machine
Will now ping  the card to see if it is still speaking to me
Nahh     Unreachable !      So where from here .?
  • New Member
  • New Member
4 years 6 months ago - 4 years 6 months ago #241213 by ALittleOffTheRails
I said before the on board network adapter card has to be setup to talk to your mesa card.
See here:
forum.linuxcnc.org/39-pncconf/45604-new-...athe?start=80#241141
You will to configure your MESA card as described here for 10.10.10.10 address.
forum.linuxcnc.org/39-pncconf/45604-new-...athe?start=10#240267
I have stated that this needs to be done before and the reason why it needs to done. John can you please appreciate that it is frustrating for those trying to help when they have to repeat themselves multiple times. I don't know if you don't read all of a post or you just have a quick glance or just don't understand some parts. I really do want to help, but it seems that I have to repeat the same information. This is what I meant by it can be a little frustrating trying help you along the way.
BTW did you get your USB to LAN\Ethernet thing working, if so what did you have to do ?
A case in point telling you how to procede:
forum.linuxcnc.org/39-pncconf/45604-new-...athe?start=90#241201
Each individual network interface needs to be configured to suit the particular settings required. Configuring just the wifi adapter does not configure the on board ethernet network adapter.
4 years 6 months ago #241218 by john11668
The point of the previous post was to advise you that things had changed and I now have an internet connection.. And then to check if (as a result ) there was any change in the way forward .
You could have said "all good , proceed as previously instructed " that would have been sufficient
USB to Lan cable connection works without any action in a windows machine . but clearly was not recognised on this one.
I will change mesa jumpers and proceed from there.
4 years 6 months ago #241264 by rodw
If you are not familiar with networking design, this video I did with a mesa card may be worth watching. BOUt 16 minutes in we go through all of the networking basics you need to know where you have 2 Network connecctions (mesa and your router)
Time to create page: 0.470 seconds
