No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationInformation required after a reboot:
The IP addresses used by you home network, ie the address used by the router.
Whether or not the router gives out addresses
With the USB to LAN connector plugged in to a USB port the following
Output of:
sudo dmesg | grep eth
This information will give an indication of whether the system is seeing the USB to LAN adapter and loading the required driver. Please note that this information is required and please do not take any shortcuts.
If you go the internal Network adapter you will need one that matches the available slot in your machine. You will need to open your machine to determine what it is. Remember that too the adapter will have to match the height of the existing card, ie if it is a low height or std height card.
For PCI cards I would look for a 2nd hand intel or 3Com based chipset and connect the MESA card to that.
eg
or
