- Thank you received: 10
I can't understand why you've set up the machine with mint.
sure if you have Linux knowledge or interest. otherwise just use the linuxcnc 2.8.2 iso of Debian buster. done
make use you have your usb dongle plugged in when you install it and it will defect the hardware and install all drives.
mint / Mx / whatever is great (I've had a few of them now) but I've now just settled for the easiest route as it tends to be the quickest too if you mess everything up and have to start again.
