New install of Mesa 7i92 on TCL lathe
4 years 6 months ago #240915 by john11668
OK so presuming it is not suitable .
What is wrong with a wired connection (lan cable ) adapted into one of my many USB ports ?
  • ALittleOffTheRails
  • New Member
  • New Member
4 years 6 months ago - 4 years 6 months ago #240922 by ALittleOffTheRails
Replied by ALittleOffTheRails on topic New install of Mesa 7i92 on TCL lathe
There is nothing wrong with a USB to LAN adapter.
I had a look at the link to your wireless adapter. The chipset is compatible with Linux.
How far have you got configuring the USB to LAN adapter.
This screenshot shows the utility to use:
Last edit: 4 years 6 months ago by ALittleOffTheRails.
4 years 6 months ago #240933 by john11668
Network connections via that route gives me just an empty pop up box .
At bottom left the plus sign allows me to add a connection . Now I am using a lan cable into a USB port so looked for a USB option but non evident in the hardware selection.
These are Bluetooth
DSL/PPPoe
Ethernet
infiniBand
Mobile Broadband
Wifi
So I am guessing the second DSL . so take me from there please
4 years 6 months ago #240934 by tommylight
@ Clive,
Almost all WiFi dongles/cards can be set to AP mode.
Also almost all AP can be set to normal "receive" mode, mostly named Bridge.
  • New Member
  • New Member
4 years 6 months ago - 4 years 6 months ago #240944 by ALittleOffTheRails
John have you fixed up the /etc/network/interfaces file yet ?
At the very least, if you have, your existing ethernet adapter should be visible.
What is the output of
ip a
And
sudo dmesg | grep eth
4 years 6 months ago #240992 by john11668
So here are results of those  terminal searches
And  following  menu / preferences  / network connections takes me here ,
So where to now please ??
Time to create page: 0.324 seconds
