Error unable to launch after pncconf.
30 Aug 2022 08:00 #250761 by snowgoer540
Replied by snowgoer540 on topic Error unable to launch after pncconf.
I’m going to delete your post in the other thread.  Double posting is discouraged and you’ve made progress here.
Did you do a package install?  If so, when the buildbot is done building chris’ changes, you’ll be able to update (should be good now).
in a terminal window, type:
sudo apt update
when that is done type:
sudo apt dist-upgrade
your linuxcnc should be updated.  No reason to redo the OS install :)
01 Sep 2022 00:18 #250905 by RobKin
Replied by RobKin on topic Error unable to launch after pncconf.
Holy Cow it works now. Thanks! Been trying to get plasmac working for a while now. Now its Qtplasmac.
06 Sep 2022 14:58 #251301 by RobKin
Commenting out hm2_5i25.0.dpll.01.timer-us gets my setup to run, how can i fix this so this component i am commenting out works?
Everytime i run pncconfig i have to edit this, just wondering if commenting this out could cause issues for me later?
  • Moderator
  • Moderator
06 Sep 2022 15:36 #251307 by tommylight
Replied by tommylight on topic Error unable to launch after pncconf.
No issues with deleting or comenting out that line, as far as i can recal.
It just means the DPLL timer is not in use.
19 Nov 2023 14:47 - 19 Nov 2023 14:55 #285900 by timo
Replied by timo on topic Error unable to launch after pncconf.
Today I had same error trying to use pncconfig and a 6i25 with 7i76 card.
"parameter or pin 'hm2_5i25.0.dpll.01.timer-us' not found"
After uncommenting the line in the hal "setp [HMOT](CARD0).dpll.01.timer-us -50" as suggested.
another error showed up
"./my_linuxCNC_machine.hal:22: parameter or pin 'hm2_5i25.0.stepgen.timer-number' not found "
mentioning the timer number I just uncommented the next line in the hal file
# setp [HMOT](CARD0).dpll.01.timer-number 1"
Then the Axis UI started and I could do the first moves. So this thread helped me to get up and running.
Is that any problem? Or is that just a glitch in the pncconf sofware?
p.s.obviously 6i25 card is treated as 5i25, and all the names are 5i25 the system works like this.
Last edit: 19 Nov 2023 14:55 by timo.
19 Nov 2023 15:09 #285903 by PCW
Replied by PCW on topic Error unable to launch after pncconf.
Yes, pncconf assumes that the firmware includes a DPLL but most PCI configs do not.
One simple solution if you still want to change things with pncconf
is to use firmware that includes a DPLL:
File Name: 5i25_7i76x2d.zip
File Size:107 KB
19 Nov 2023 17:07 #285917 by timo
Thank you for reply.
I understand I should change the bitfile on the 6i25, is that correct?
Is that done using mesaflash software? Have to look into that.
  • Moderator
  • Moderator
19 Nov 2023 17:13 #285918 by tommylight
Yes and yes.
Although you should make sure the 5i25 and 6i25 use the same firmware.
20 Nov 2023 12:20 - 20 Nov 2023 12:22 #286028 by timo
I do not really know what am I doing (yet again :-) , there is a pattern )
I copied the 5i25_7i76.bit file into the /bin folder
Then typed
mesaflash --device 6i25 --readhmid there was an error message no device found, so I tried
mesaflash --device 5i25 --readhmid, a list of names and pin functions shows up.
Then typed:
mesaflash --device 5i25 --write 5i25_7i76x2.bit
Some messages appear, finally it asked me to power cycle or use reload.
type:
mesaflash --device 5i25 --reload
Then I tried to uncomment the lines with dpll timer back in the hal file.
Result: machine starts.
Was that correct?
Last edit: 20 Nov 2023 12:22 by timo.
19 Dec 2023 22:03 #288620 by Miller Turner
Replied by Miller Turner on topic Error unable to launch after pncconf.
Dear all,
I just did a fresh install of 2.9.1, using "www.linuxcnc.org/iso/linuxcnc_2.9.1-amd64.hybrid.iso" from "linuxcnc.org/docs/html/getting-started/getting-linuxcnc.html" followed by a setup with pncconf with the exact same settings as my previous working 2.8.4 setup.
At startup od linuxcnc I unexpectedly get this error "parameter or pin 'hm2_5i25.0.dpll.01.timer-us' not found"
Anyone who has a clue how to solve this?
Any help is very much appreciated :)
Time to create page: 0.548 seconds
