Error unable to launch after pncconf.
- Thank you received: 5325
19 Dec 2023 22:44 #288622
Replied by PCW on topic Error unable to launch after pncconf.
There are two solutions if you read a few posts back in this thread...
- Thank you received: 4149
20 Dec 2023 08:01 #288648
Replied by rodw on topic Error unable to launch after pncconf.
Time to edit manually. comment out the offending line until you can open it, Then use halshow to get the correct pin names and edit your config accordingly
- Miller Turner
20 Dec 2023 20:35 #288699
by Miller Turner
Replied by Miller Turner on topic Error unable to launch after pncconf.
Thank you so much for helping out.
I had to comment out 2 lines:
hm2_5i25.0.dpll.01.timer-us
hm2_5i25_0.stepgen.timer-number
AND I had to disable the "custom GladeVCP GUI panel" to get linuxcnc to start up again.
In the end I could still use "custom PyVCP GUI panel" instead to show the motor speed
So at least the system is now up and running under 2.9.1 (I still have 2.8.4 as backup available)
Again, thank you very much, I hope I did the right things...
- rob123
12 Apr 2026 06:45 #345435
by rob123
Replied by rob123 on topic Error unable to launch after pncconf.
Hello PCW, I am having the same trouble.
Do you have or know where I can get a copy of 5i25_prob_rfx2.bit that includes a DPLL?
Thanks Robert?
Thanks Robert?
12 Apr 2026 14:46 #345451
Its possible to build one but most 5I25 configurations lack the DPLL because
the jitter is so much lower on PCI/PCIE cards that there is little benefit from
adding the DPLL.
adding the DPLL.
The following user(s) said Thank You: rob123
Time to create page: 0.082 seconds
