No channel 4 stepgen direction on Mesa 7i92T
3 years 7 months ago #267659 by kenwoodhf
jan@cnc:~$ mesaflash --device ethernet --addr 10.10.10.10
ETH device 7I92T at ip=10.10.10.10
jan@cnc:~$
3 years 7 months ago - 3 years 7 months ago #267660 by PCW
Then
mesaflash --device 7i92t --addr 10.10.10.10 --readhmid
should work
As should:
mesaflash --device ethernet --addr 10.10.10.10 --readhmid
Last edit: 3 years 7 months ago by PCW.
3 years 7 months ago #267662 by kenwoodhf
Thanks for all your help
WORKS
Now i can see if I can mess up the firmware install.
I hope this post will help some other people.
Thanks again
Jan
3 years 7 months ago #267663 by PCW
if
Does not work, that suggests you have an old copy of mesaflash
Did you install the latest version? (sudo make install)
3 years 7 months ago #267702 by kenwoodhf
I went to the Git-Hub and installed the mesaflash utillity following the instructions which included "sudo make install"
The version installed is 3.4.7
What is the latest version?
Jan
3 years 7 months ago #267703 by PCW
That is the latest version:
peter@peter-HP-EliteDesk-800-G1-USDT:~$ mesaflash --version
Mesaflash version 3.4.7
peter@peter-HP-EliteDesk-800-G1-USDT:~$ mesaflash --device 7i92t --addr 10.10.10.10 --readhmid
Configuration Name: HOSTMOT2
BoardName : MESA7I92
FPGA Size: 20 KGates
FPGA Pins: 256
Number of IO Ports: 2
Time to create page: 0.467 seconds
