7i92T with 7i77 linuxcnc keeps terminating
- RK
30 Apr 2023 16:21 #270313
by RK
Replied by RK on topic 7i92T with 7i77 linuxcnc keeps terminating
Hi PCW,
Coalescing is definitely part of my problem. When I change it in the terminal it is only allowing me a temporary change. The ping times are much better but change after reboot. I tried following the instructions in the manual but for some reason I'm not doing something right. I don't know what keys to use in the terminal to edit the interfaces file. When I try to edit it I keep accumulating temporary .swp files. The key commands don't seem to make a lot of sense to me in the terminal edit environment.
- Thank you received: 5308
30 Apr 2023 16:27 #270314
Replied by PCW on topic 7i92T with 7i77 linuxcnc keeps terminating
What editor are you using? gedit, geany or xedit should all be fine
say
cd /etc/network
sudo xedit interfaces
say
cd /etc/network
- RK
02 May 2023 22:42 #270515
by RK
I tried xedit, Vim, and Geany. None of them will let me save the changes to the interfaces file. I'm not sure what I'm doing wrong.
02 May 2023 22:44 #270516
did you use sudo?
- RK
02 May 2023 22:48 #270518
by RK
yes
02 May 2023 23:00 - 02 May 2023 23:00 #270520
Strange...Here is the exact sequence I used just now to edit the interfaces file:
pcw@pcw-HP-Compaq-Elite-8300-USDT:~/Desktop$ cd /etc/network
pcw@pcw-HP-Compaq-Elite-8300-USDT:/etc/network$ sudo xedit interfaces
[sudo] password for pcw:
<< edit interfaces file, make a change then save & exit >>>
pcw@pcw-HP-Compaq-Elite-8300-USDT:/etc/network$ ls -lrt
total 28
drwxr-xr-x 2 root root 4096 May 2 2019 interfaces.d
-rw-r--r-- 1 root root 142 Jan 4 2022 interfaces~
drwxr-xr-x 2 root root 4096 Jan 4 2022 if-pre-up.d
drwxr-xr-x 2 root root 4096 Jan 4 2022 if-post-down.d
drwxr-xr-x 2 root root 4096 Jan 4 2022 if-up.d
drwxr-xr-x 2 root root 4096 Jan 4 2022 if-down.d
-rw-r--r-- 1 root root 143 May 2 15:52 interfaces
<< notice interface fie has been updated>>
total 28
Last edit: 02 May 2023 23:00 by PCW.
- RK
02 May 2023 23:17 #270522
by RK
I will try again but I can't until tomorrow. Thanks for the responce. I'll let you know what I find.
- RK
03 May 2023 21:54 #270590
by RK
It worked this time. I missed the space after cd the first time. Thank You!
Time to create page: 0.099 seconds
