Mesa 7I92TM Parallel port pin mapping
21 Aug 2024 17:56 - 21 Aug 2024 17:58 #308327 by DougM
Replied by DougM on topic Mesa 7I92TM Parallel port pin mapping
Ah, so the .pin file is the descriptor for the .bin file. That's helpful :-)
I have 3 of these things and this is the first one I've ever flashed. Presumably the factory image has some standard pinout that miraculously matched the pin in's of the other two devices. That's what I want to get back to.
I put the thing on the scope and it's just not right. If I scope the original computer with native parallel i get a nice clean step signal, but if I scope this card I only get intermittent step pulses. But the width of the high pulse is the same as the native parallel.
So I want to get back to the native firmware just to see if the intermittent problem goes away. I think it will because when I first go this card it did work on a different machine.
Thanks for the explanation on the .pin and .bit files - that helped a lot.  Do I need to worry about Table1 and Table2 mapping?  Or is that all taken care of in PNCConf?
Last edit: 21 Aug 2024 17:58 by DougM.
21 Aug 2024 18:32 #308331 by PCW
Replied by PCW on topic Mesa 7I92TM Parallel port pin mapping
I suspect the default firmware is a 5ABOB type parallel port firmware
but I can check later.
Hunting on the step/dir outputs is more likely a setup issue than firmware
(since all firmware stepgens are identical)
21 Aug 2024 18:50 #308333 by DougM
I did a diff on the two readhmid outputs from the re-flashed one vs. another one that I hadn't touched and they were the same for the pins in question. So either the flash didn't take or something else is broken. (there were other differences in the two files)
In any event for now I'm going to go back to making a DB-25 converter since I've exceeded my rabbit hole depth limit :-)
Thank you for sticking with me.
21 Aug 2024 19:42 - 21 Aug 2024 19:43 #308337 by PCW
After flashing, you need to power cycle  the 7I92 or use mesaflash's  --reload option
You should not need to use any kind of cable adapter
If you have a unique breakout, firmware can be built for this in a few minutes
Last edit: 21 Aug 2024 19:43 by PCW.
Time to create page: 0.094 seconds
