Yes if you set up the home_sequence correctly. Read the link again another 3 times,,,,Thanks. I’ll order the switches.
Having a blast is not my goal here. I need a working tool.
To be clear, when I set up the limit switches the software will treat the two Y motors as one? Currently they are being treated as separate axes, which makes it impossible to move the gantry to a home position.
