7i92T and mx3660 request for help
04 Mar 2026 22:14 #343870 by tommylight
Replied by tommylight on topic 7i92T and mx3660 request for help
Funny, the homing was INVERTED in Stepconf, but now is not in Pnnconf. Also the latest Pnnconf instructions do not match the Pnnconf I see on my machine. ????? documentation must be lagging I guess, realize everybody is busy and this is a free program......
Parallel port requires pulling inputs down to trigger,
Mesa can have inputs set for pull down or pull up, in hal
Mesa can use all pins as inputs or as outputs, in any combination, and they are much, much faster than parallel port, so it is impossible to have all possible combinations in a wizard.
05 Mar 2026 12:17 #343889 by ClarkSavage
Replied by ClarkSavage on topic 7i92T and mx3660 request for help
Ok, got it, good to know - and I do not know that much about Linuxcnc and lastly, Pnnconf / MESA stuff. All new.
But, all limits working now. I just need to check the probe setup - think that I can do after the limit switch and HalShow stuff initiation.
But, my ESTOP is still beyond me. Saw threads where JT and I believe a few others talked about inserting lines that linked the ESTOP pin to other pins or feedback - tries several but beyond me once again.
ESTOP - loaded all pins and all ESTOP, Abort, Charge pump references into HalShow, enabled [it's a NC switch] my external ESTOP button and nothing in Halshow changed color. Yes, my external button is wired into the mx3660, and yes it shuts down the motors on push.
I tried to move the ESTOP to different pins that were open and then Halshow - no change. The probe pins work in Halshow so I know that is at least on the right pin and gives feedback - I can figure that out.
So any suggestions on ESTOP? Else I will live with it the way it is. Still have a lot of changes to do with travel and positioning in the ini for axes but that's easy stuff, just takes me a little longer one step at a time.
05 Mar 2026 21:17 #343922 by ClarkSavage
Ok, everything has settled, homes and I have a working machine but ESTOP external button versus software - the external button kills the mx3660 but does not trip in LinuxCNC
Played a little, read some, and am giving the following thinking someone may have the fancy answer.
ESTOP external is NC switch setup, has a NO side not using.
Machine enabled Halshow results:
  • ESTOP External OFF:     pin.003.in  RED
  • ESTOP External ON:     pin.003.in  RED
  •          pin.003.out              no change
    Software ESTOP:
    • OFF         pin.003.in                 RED
    • OFF         pin.003.in_not          YELLOW
    • OFF         pin.003.out              YELLOW
    • ON         pin.003.in                   RED
    • OFF         pin.003.out               RED
      Understand from reading that the output/input somehow can be linked to false or other pin - tried, I get config errors, no load.
      Again, not a deal breaker, but when the external ESTOP is triggered such as during a home, the motors stop but when I raise the button the machine continues - like it paused not ESTOPPED. That's a little disconcerting.
      Attaching HAL file.
      File Name: 010.hal
      File Size:10 KB
05 Mar 2026 21:29 #343924 by tommylight
There is no "E-stop in" in your hal file, so LinuxCNC has no way of knowing if the button is pressed or not.
Time to create page: 0.111 seconds
