Remap 3D Cubic Spline Interpolation code by Python
2 years 3 weeks ago #311763 by Todd Zuercher
Interesting. I had no idea that a spline could be one dimensional. Would the same math mathematical process work to expanded to 5 (or more) axis?
2 years 3 weeks ago #311794 by Aciera
Well, it isn't _really_ one dimensional but rather a curve in the t/x, t/y or t/z space with 't' being a parameter that increases like time or arc length. This works for any number of axes but for motion control it's usefulness would be very limited as we don't have much control over the deviation of the resulting path from the polyline that connects the given points.
2 years 2 weeks ago #312342 by jurod
Perfect, I'm going to try.
1 year 11 months ago - 1 year 11 months ago #314195 by jurod
Very well. Thanks.
I also made adjustments for the XYZA and XYZBC axes.
Axes XYZA:
#! /usr/bin/python3 """ 3-D spline interpolation (with graph drawing by matplotlib) """ import matplotlib.pyplot as plt import sys import os import traceback class SplineInterpolation:     def __init__(self, ts, ds):         """ Initialization         :param list ts: item number list of given points         :param list ds: coordinate list of given points         """         self.ts, self.ds = ts, ds         self.n = len(self.ts) - 1         h = self.__calc_h()         w = self.__calc_w(h)         matrix = self.__gen_matrix(h, w)         v = [0] + self.__gauss_jordan(matrix) + [0]         self.b = self.__calc_b(v)         self.a = self.__calc_a(v)         self.d = self.__calc_d()         self.c = self.__calc_c(v)     def interpolate(self, t):         """ Interpolation         :param  float t: value for a interpolate target         :return float  : computated y-value         """         try:             i = self.__search_i(t)             return self.a[i] * (t - self.ts[i]) ** 3 \                  + self.b[i] * (t - self.ts[i]) ** 2 \                  + self.c[i] * (t - self.ts[i]) \                  + self.d[i]         except Exception as e:             raise     def __calc_h(self):         """ H calculation         :return list: h-values         """         try:             return [self.ts[i + 1] - self.ts[i] for i in range(self.n)]         except Exception as e:             raise     def __calc_w(self, h):         """ W calculation         :param  list h: h-values         :return list  : w-values         """         try:             return [                 6 * ((self.ds[i + 1] - self.ds[i]) / h[i]                    - (self.ds[i] - self.ds[i - 1]) / h[i - 1])                 for i in range(1, self.n)             ]         except Exception as e:             raise     def __gen_matrix(self, h, w):         """ Matrix generation         :param  list   h: h-values         :param  list   w: w-values         :return list mtx: generated 2-D matrix         """         mtx = [[0 for _ in range(self.n)] for _ in range(self.n - 1)]         try:             for i in range(self.n - 1):                 mtx[i][i]     = 2 * (h[i] + h[i + 1])                 mtx[i][-1]    = w[i]                 if i == 0:                     continue                 mtx[i - 1][i] = h[i]                 mtx[i][i - 1] = h[i]             return mtx         except Exception as e:             raise     def __gauss_jordan(self, matrix):         """ Solving of simultaneous linear equations             with Gauss-Jordan's method         :param  list mtx: list of 2-D matrix         :return list   v: answers list of simultaneous linear equations         """         v = []         n = self.n - 1         try:             for k in range(n):                 p = matrix[k][k]                 for j in range(k, n + 1):                     matrix[k][j] /= p                 for i in range(n):                     if i == k:                         continue                     d = matrix[i][k]                     for j in range(k, n + 1):                         matrix[i][j] -= d * matrix[k][j]             for row in matrix:                 v.append(row[-1])             return v         except Exception as e:             raise     def __calc_a(self, v):         """ A calculation         :param  list v: v-values         :return list  : a-values         """         try:             return [                 (v[i + 1] - v[i])               / (6 * (self.ts[i + 1] - self.ts[i]))                 for i in range(self.n)             ]         except Exception as e:             raise     def __calc_b(self, v):         """ B calculation         :param  list v: v-values         :return list  : b-values         """         try:             return [v[i] / 2.0 for i in range(self.n)]         except Exception as e:             raise     def __calc_c(self, v):         """ C calculation         :param  list v: v-values         :return list  : c-values         """         try:             return [                 (self.ds[i + 1] - self.ds[i]) / (self.ts[i + 1] - self.ts[i]) \               - (self.ts[i + 1] - self.ts[i]) * (2 * v[i] + v[i + 1]) / 6                 for i in range(self.n)             ]         except Exception as e:             raise     def __calc_d(self):         """ D calculation         :return list: c-values         """         try:             return self.ds         except Exception as e:             raise     def __search_i(self, t):         """ Index searching         :param float t: t-value         :return  int i: index         """         i, j = 0, len(self.ts) - 1         try:             while i < j:                 k = (i + j) // 2                 if self.ts[k] < t:                     i = k + 1                 else:                     j = k             if i > 0:                 i -= 1             return i         except Exception as e:             raise class Graph:     def __init__(self, xs_0, ys_0, zs_0, xs_1, ys_1, zs_1):         self.xs_0, self.ys_0, self.zs_0, self.xs_1, self.ys_1, self.zs_1 = xs_0, ys_0, zs_0, xs_1, ys_1, zs_1     def plot2d(self):         try:             plt.title("2-D Spline Interpolation in XY/XZ")             plt.scatter(                 self.xs_1, self.ys_1, c = "g",                 label = "interpolated points XY", marker = "+"             )             plt.scatter(                 self.xs_0, self.ys_0, c = "r",                 label = "given points XY"             )             plt.scatter(                 self.xs_1, self.zs_1, c = "b",                 label = "interpolated points XZ", marker = "+"             )             plt.scatter(                 self.xs_0, self.zs_0, c = "k",                 label = "given points XZ"             )             plt.xlabel("x")             plt.ylabel("y,z")             plt.legend(loc = 2)             plt.grid(color = "gray", linestyle = "--")             #plt.show()             #plt.savefig("spline_interpolation.png")         except Exception as e:             raise     def plot3d(self):         ax = plt.figure().add_subplot(projection='3d')         x = self.xs_1         y = self.ys_1         z = self.zs_1         ax.scatter(x, y, z, c='b', label='Interpolated points')         ax.scatter(X, Y, Z, c='r', label='Given points')         # Make legend, set axes limits and labels         ax.legend()         ax.set_xlim(min(X),max(X))         ax.set_ylim(min(Y),max(Y))         ax.set_zlim(min(Z),max(Z))         ax.set_xlabel('X')         ax.set_ylabel('Y')         ax.set_zlabel('Z')         # Customize the view angle so it's easier to see that the scatter points lie         # on the plane y=0         ax.view_init(elev=20., azim=-35)         plt.show() if __name__ == '__main__':     # (N + 1) points     T,X,Y,Z,A = [],[],[],[],[]     fileName  = './points_input.txt'     import csv     with open(fileName, 'r') as f:         reader = csv.reader(f)         point_data = list(reader)         for line in point_data:             X.append(float(line[0]))             Y.append(float(line[1]))             Z.append(float(line[2]))             A.append(float(line[3]))     print('X:', X)     print('Y:', Y)     print('Z:', Z)     print('A:', A)     n=0     for x in X:         T.append(n+1.0)            n += 1     print('T: ', T)              #T = [1.0,2.0,3.0,4.0,5.0,6.0]     #X = [0.0, 2.0, 3.0, 5.0, 7.0, 8.0]     #Y = [0.8, 2.8, 3.2, 1.9, 4.5, 2.5]     #Z = [-0.5, 1.8, 2.2, 0.9, 3.5, -1.5]     S   = 0.1        # Step for interpolation     S_1 = 1 / S      # Inverse of S     xs_g, ys_g, zs_g, as_g = [], [], [], []  # List for graph     try:         # 3-D spline interpolation         si = SplineInterpolation(T, X)         for t in [t / S_1 for t in range(int(T[0] / S), int(T[-1] / S) + 1)]:             x= si.interpolate(t)             #print("{:8.4f}, {:8.4f}".format(t, x))             xs_g.append(x)                 si = SplineInterpolation(T, Y)         for t in [t / S_1 for t in range(int(T[0] / S), int(T[-1] / S) + 1)]:             y = si.interpolate(t)             #print("{:8.4f}, {:8.4f}".format(t, y))             ys_g.append(y)         si = SplineInterpolation(T, Z)         for t in [t / S_1 for t in range(int(T[0] / S), int(T[-1] / S) + 1)]:             z = si.interpolate(t)             #print("{:8.4f}, {:8.4f}".format(t, z))             zs_g.append(z)         si = SplineInterpolation(T, A)         for t in [t / S_1 for t in range(int(T[0] / S), int(T[-1] / S) + 1)]:             a = si.interpolate(t)             #print("{:8.4f}, {:8.4f}".format(t, z))             as_g.append(a)         # Write output to file         file_out = 'output_file.txt'         print('Writing output to ',file_out)         n=0         output = open(file_out, 'w')         for x in xs_g:             string=("G1 X{:4.2f} Y{:4.2f} Z{:4.2f} A{:4.2f}\n".format(xs_g[n], ys_g[n], zs_g[n], as_g[n]))             output.write(string)             n += 1         # Closing file         output.close()         # Graph drawing         g = Graph(X, Y, Z, xs_g, ys_g, zs_g)         g.plot2d()         g.plot3d()     except Exception as e:         traceback.print_exc()         sys.exit(1)
Axes XYZBC:
#! /usr/bin/python3 """ 3-D spline interpolation (with graph drawing by matplotlib) """ import matplotlib.pyplot as plt import sys import os import traceback class SplineInterpolation:     def __init__(self, ts, ds):         """ Initialization         :param list ts: item number list of given points         :param list ds: coordinate list of given points         """         self.ts, self.ds = ts, ds         self.n = len(self.ts) - 1         h = self.__calc_h()         w = self.__calc_w(h)         matrix = self.__gen_matrix(h, w)         v = [0] + self.__gauss_jordan(matrix) + [0]         self.b = self.__calc_b(v)         self.a = self.__calc_a(v)         self.d = self.__calc_d()         self.c = self.__calc_c(v)     def interpolate(self, t):         """ Interpolation         :param  float t: value for a interpolate target         :return float  : computated y-value         """         try:             i = self.__search_i(t)             return self.a[i] * (t - self.ts[i]) ** 3 \                  + self.b[i] * (t - self.ts[i]) ** 2 \                  + self.c[i] * (t - self.ts[i]) \                  + self.d[i]         except Exception as e:             raise     def __calc_h(self):         """ H calculation         :return list: h-values         """         try:             return [self.ts[i + 1] - self.ts[i] for i in range(self.n)]         except Exception as e:             raise     def __calc_w(self, h):         """ W calculation         :param  list h: h-values         :return list  : w-values         """         try:             return [                 6 * ((self.ds[i + 1] - self.ds[i]) / h[i]                    - (self.ds[i] - self.ds[i - 1]) / h[i - 1])                 for i in range(1, self.n)             ]         except Exception as e:             raise     def __gen_matrix(self, h, w):         """ Matrix generation         :param  list   h: h-values         :param  list   w: w-values         :return list mtx: generated 2-D matrix         """         mtx = [[0 for _ in range(self.n)] for _ in range(self.n - 1)]         try:             for i in range(self.n - 1):                 mtx[i][i]     = 2 * (h[i] + h[i + 1])                 mtx[i][-1]    = w[i]                 if i == 0:                     continue                 mtx[i - 1][i] = h[i]                 mtx[i][i - 1] = h[i]             return mtx         except Exception as e:             raise     def __gauss_jordan(self, matrix):         """ Solving of simultaneous linear equations             with Gauss-Jordan's method         :param  list mtx: list of 2-D matrix         :return list   v: answers list of simultaneous linear equations         """         v = []         n = self.n - 1         try:             for k in range(n):                 p = matrix[k][k]                 for j in range(k, n + 1):                     matrix[k][j] /= p                 for i in range(n):                     if i == k:                         continue                     d = matrix[i][k]                     for j in range(k, n + 1):                         matrix[i][j] -= d * matrix[k][j]             for row in matrix:                 v.append(row[-1])             return v         except Exception as e:             raise     def __calc_a(self, v):         """ A calculation         :param  list v: v-values         :return list  : a-values         """         try:             return [                 (v[i + 1] - v[i])               / (6 * (self.ts[i + 1] - self.ts[i]))                 for i in range(self.n)             ]         except Exception as e:             raise     def __calc_b(self, v):         """ B calculation         :param  list v: v-values         :return list  : b-values         """         try:             return [v[i] / 2.0 for i in range(self.n)]         except Exception as e:             raise     def __calc_c(self, v):         """ C calculation         :param  list v: v-values         :return list  : c-values         """         try:             return [                 (self.ds[i + 1] - self.ds[i]) / (self.ts[i + 1] - self.ts[i]) \               - (self.ts[i + 1] - self.ts[i]) * (2 * v[i] + v[i + 1]) / 6                 for i in range(self.n)             ]         except Exception as e:             raise     def __calc_d(self):         """ D calculation         :return list: c-values         """         try:             return self.ds         except Exception as e:             raise     def __search_i(self, t):         """ Index searching         :param float t: t-value         :return  int i: index         """         i, j = 0, len(self.ts) - 1         try:             while i < j:                 k = (i + j) // 2                 if self.ts[k] < t:                     i = k + 1                 else:                     j = k             if i > 0:                 i -= 1             return i         except Exception as e:             raise class Graph:     def __init__(self, xs_0, ys_0, zs_0, xs_1, ys_1, zs_1):         self.xs_0, self.ys_0, self.zs_0, self.xs_1, self.ys_1, self.zs_1 = xs_0, ys_0, zs_0, xs_1, ys_1, zs_1     def plot2d(self):         try:             plt.title("2-D Spline Interpolation in XY/XZ")             plt.scatter(                 self.xs_1, self.ys_1, c = "g",                 label = "interpolated points XY", marker = "+"             )             plt.scatter(                 self.xs_0, self.ys_0, c = "r",                 label = "given points XY"             )             plt.scatter(                 self.xs_1, self.zs_1, c = "b",                 label = "interpolated points XZ", marker = "+"             )             plt.scatter(                 self.xs_0, self.zs_0, c = "k",                 label = "given points XZ"             )             plt.xlabel("x")             plt.ylabel("y,z")             plt.legend(loc = 2)             plt.grid(color = "gray", linestyle = "--")             #plt.show()             #plt.savefig("spline_interpolation.png")         except Exception as e:             raise     def plot3d(self):         ax = plt.figure().add_subplot(projection='3d')         x = self.xs_1         y = self.ys_1         z = self.zs_1         ax.scatter(x, y, z, c='b', label='Interpolated points')         ax.scatter(X, Y, Z, c='r', label='Given points')         # Make legend, set axes limits and labels         ax.legend()         ax.set_xlim(min(X),max(X))         ax.set_ylim(min(Y),max(Y))         ax.set_zlim(min(Z),max(Z))         ax.set_xlabel('X')         ax.set_ylabel('Y')         ax.set_zlabel('Z')         # Customize the view angle so it's easier to see that the scatter points lie         # on the plane y=0         ax.view_init(elev=20., azim=-35)         plt.show() if __name__ == '__main__':     # (N + 1) points     T,X,Y,Z,B,C = [],[],[],[],[],[]     fileName  = './points_input.txt'     import csv     with open(fileName, 'r') as f:         reader = csv.reader(f)         point_data = list(reader)         for line in point_data:             X.append(float(line[0]))             Y.append(float(line[1]))             Z.append(float(line[2]))             B.append(float(line[3]))             C.append(float(line[4]))     print('X:', X)     print('Y:', Y)     print('Z:', Z)     print('B:', B)     print('C:', C)     n=0     for x in X:         T.append(n+1.0)            n += 1     print('T: ', T)              #T = [1.0,2.0,3.0,4.0,5.0,6.0]     #X = [0.0, 2.0, 3.0, 5.0, 7.0, 8.0]     #Y = [0.8, 2.8, 3.2, 1.9, 4.5, 2.5]     #Z = [-0.5, 1.8, 2.2, 0.9, 3.5, -1.5]     S   = 0.1        # Step for interpolation     S_1 = 1 / S      # Inverse of S     xs_g, ys_g, zs_g, bs_g, cs_g = [], [], [], [], []  # List for graph     try:         # 3-D spline interpolation         si = SplineInterpolation(T, X)         for t in [t / S_1 for t in range(int(T[0] / S), int(T[-1] / S) + 1)]:             x= si.interpolate(t)             #print("{:8.4f}, {:8.4f}".format(t, x))             xs_g.append(x)                 si = SplineInterpolation(T, Y)         for t in [t / S_1 for t in range(int(T[0] / S), int(T[-1] / S) + 1)]:             y = si.interpolate(t)             #print("{:8.4f}, {:8.4f}".format(t, y))             ys_g.append(y)         si = SplineInterpolation(T, Z)         for t in [t / S_1 for t in range(int(T[0] / S), int(T[-1] / S) + 1)]:             z = si.interpolate(t)             #print("{:8.4f}, {:8.4f}".format(t, z))             zs_g.append(z)         si = SplineInterpolation(T, B)         for t in [t / S_1 for t in range(int(T[0] / S), int(T[-1] / S) + 1)]:             b = si.interpolate(t)             #print("{:8.4f}, {:8.4f}".format(t, b))             bs_g.append(b)         si = SplineInterpolation(T, C)         for t in [t / S_1 for t in range(int(T[0] / S), int(T[-1] / S) + 1)]:             c = si.interpolate(t)             #print("{:8.4f}, {:8.4f}".format(t, c))             cs_g.append(c)         # Write output to file         file_out = 'output_file.txt'         print('Writing output to ',file_out)         n=0         output = open(file_out, 'w')         for x in xs_g:             string=("G1 X{:4.2f} Y{:4.2f} Z{:4.2f} B{:4.2f} C{:4.2f}\n".format(xs_g[n], ys_g[n], zs_g[n], bs_g[n], cs_g[n]))             output.write(string)             n += 1         # Closing file         output.close()         # Graph drawing         g = Graph(X, Y, Z, xs_g, ys_g, zs_g)         g.plot2d()         g.plot3d()     except Exception as e:         traceback.print_exc()         sys.exit(1)
Last edit: 1 year 11 months ago by jurod.
Time to create page: 0.083 seconds
