Remap 3D Cubic Spline Interpolation code by Python
2 years 3 weeks ago #311711 by jurod
This code should be correct on a 3d spline
 #! /usr/local/bin/python3.6 """ 3-D spline interpolation (with graph drawing by matplotlib) """ import matplotlib.pyplot as plt import sys import traceback class SplineInterpolation: def __init__(self, xs, ys): """ Initialization :param list xs: x-coordinate list of given points :param list ys: y-coordinate list of given points """ self.xs, self.ys = xs, ys self.n = len(self.xs) - 1 h = self.__calc_h() w = self.__calc_w(h) matrix = self.__gen_matrix(h, w) v = [0] + self.__gauss_jordan(matrix) + [0] self.b = self.__calc_b(v) self.a = self.__calc_a(v) self.d = self.__calc_d() self.c = self.__calc_c(v) def interpolate(self, t): """ Interpolation :param float t: x-value for a interpolate target :return float : computated y-value """ try: i = self.__search_i(t) return self.a[i] * (t - self.xs[i]) ** 3 \ + self.b[i] * (t - self.xs[i]) ** 2 \ + self.c[i] * (t - self.xs[i]) \ + self.d[i] except Exception as e: raise def __calc_h(self): """ H calculation :return list: h-values """ try: return [self.xs[i + 1] - self.xs[i] for i in range(self.n)] except Exception as e: raise def __calc_w(self, h): """ W calculation :param list h: h-values :return list : w-values """ try: return [ 6 * ((self.ys[i + 1] - self.ys[i]) / h[i] - (self.ys[i] - self.ys[i - 1]) / h[i - 1]) for i in range(1, self.n) ] except Exception as e: raise def __gen_matrix(self, h, w): """ Matrix generation :param list h: h-values :param list w: w-values :return list mtx: generated 2-D matrix """ mtx = [[0 for _ in range(self.n)] for _ in range(self.n - 1)] try: for i in range(self.n - 1): mtx[i][i] = 2 * (h[i] + h[i + 1]) mtx[i][-1] = w[i] if i == 0: continue mtx[i - 1][i] = h[i] mtx[i][i - 1] = h[i] return mtx except Exception as e: raise def __gauss_jordan(self, matrix): """ Solving of simultaneous linear equations with Gauss-Jordan's method :param list mtx: list of 2-D matrix :return list v: answers list of simultaneous linear equations """ v = [] n = self.n - 1 try: for k in range(n): p = matrix[k][k] for j in range(k, n + 1): matrix[k][j] /= p for i in range(n): if i == k: continue d = matrix[i][k] for j in range(k, n + 1): matrix[i][j] -= d * matrix[k][j] for row in matrix: v.append(row[-1]) return v except Exception as e: raise def __calc_a(self, v): """ A calculation :param list v: v-values :return list : a-values """ try: return [ (v[i + 1] - v[i]) / (6 * (self.xs[i + 1] - self.xs[i])) for i in range(self.n) ] except Exception as e: raise def __calc_b(self, v): """ B calculation :param list v: v-values :return list : b-values """ try: return [v[i] / 2.0 for i in range(self.n)] except Exception as e: raise def __calc_c(self, v): """ C calculation :param list v: v-values :return list : c-values """ try: return [ (self.ys[i + 1] - self.ys[i]) / (self.xs[i + 1] - self.xs[i]) \ - (self.xs[i + 1] - self.xs[i]) * (2 * v[i] + v[i + 1]) / 6 for i in range(self.n) ] except Exception as e: raise def __calc_d(self): """ D calculation :return list: c-values """ try: return self.ys except Exception as e: raise def __search_i(self, t): """ Index searching :param float t: t-value :return int i: index """ i, j = 0, len(self.xs) - 1 try: while i < j: k = (i + j) // 2 if self.xs[k] < t: i = k + 1 else: j = k if i > 0: i -= 1 return i except Exception as e: raise class Graph: def __init__(self, xs_0, ys_0, xs_1, ys_1): self.xs_0, self.ys_0, self.xs_1, self.ys_1 = xs_0, ys_0, xs_1, ys_1 def plot(self): """ Graph plotting """ try: plt.title("3-D Spline Interpolation") plt.scatter( self.xs_1, self.ys_1, c = "b", label = "interpolated points", marker = "+" ) plt.scatter( self.xs_0, self.ys_0, c = "r", label = "given points" ) plt.xlabel("x") plt.ylabel("y") plt.legend(loc = 2) plt.grid(color = "gray", linestyle = "--") #plt.show() plt.savefig("spline_interpolation.png") except Exception as e: raise if __name__ == '__main__': # (N + 1) points X = [0.0, 2.0, 3.0, 5.0, 7.0, 8.0] Y = [0.8, 2.8, 3.2, 1.9, 4.5, 2.5] S = 0.1 # Step for interpolation S_1 = 1 / S # Inverse of S xs_g, ys_g = [], [] # List for graph try: # 3-D spline interpolation si = SplineInterpolation(X, Y) for x in [x / S_1 for x in range(int(X[0] / S), int(X[-1] / S) + 1)]: y = si.interpolate(x) print("{:8.4f}, {:8.4f}".format(x, y)) xs_g.append(x) ys_g.append(y) # Graph drawing g = Graph(X, Y, xs_g, ys_g) g.plot() except Exception as e: traceback.print_exc() sys.exit(1)
2 years 3 weeks ago - 2 years 3 weeks ago #311714 by Aciera
A curve in the XY plane is a 2D curve even if the title says '3-D':
[edit]
So basically you would need to run this for XY and XZ coordinate pairs separately and then reconstruct the XYZ coordinates. Shouldn't be too difficult really.
Last edit: 2 years 3 weeks ago by Aciera.
2 years 3 weeks ago #311722 by Aciera
Your code sample expanded to 3D:
 #! /usr/local/bin/python3.6 """ 3-D spline interpolation (with graph drawing by matplotlib) """ import matplotlib.pyplot as plt import sys import traceback class SplineInterpolation_xy:     def __init__(self, xs, ys):         """ Initialization         :param list xs: x-coordinate list of given points         :param list ys: y-coordinate list of given points         """         self.xs, self.ys = xs, ys         self.n = len(self.xs) - 1         h = self.__calc_h()         w = self.__calc_w(h)         matrix = self.__gen_matrix(h, w)         v = [0] + self.__gauss_jordan(matrix) + [0]         self.b = self.__calc_b(v)         self.a = self.__calc_a(v)         self.d = self.__calc_d()         self.c = self.__calc_c(v)     def interpolate(self, t):         """ Interpolation         :param  float t: x-value for a interpolate target         :return float  : computated y-value         """         try:             i = self.__search_i(t)             return self.a[i] * (t - self.xs[i]) ** 3 \                  + self.b[i] * (t - self.xs[i]) ** 2 \                  + self.c[i] * (t - self.xs[i]) \                  + self.d[i]         except Exception as e:             raise     def __calc_h(self):         """ H calculation         :return list: h-values         """         try:             return [self.xs[i + 1] - self.xs[i] for i in range(self.n)]         except Exception as e:             raise     def __calc_w(self, h):         """ W calculation         :param  list h: h-values         :return list  : w-values         """         try:             return [                 6 * ((self.ys[i + 1] - self.ys[i]) / h[i]                    - (self.ys[i] - self.ys[i - 1]) / h[i - 1])                 for i in range(1, self.n)             ]         except Exception as e:             raise     def __gen_matrix(self, h, w):         """ Matrix generation         :param  list   h: h-values         :param  list   w: w-values         :return list mtx: generated 2-D matrix         """         mtx = [[0 for _ in range(self.n)] for _ in range(self.n - 1)]         try:             for i in range(self.n - 1):                 mtx[i][i]     = 2 * (h[i] + h[i + 1])                 mtx[i][-1]    = w[i]                 if i == 0:                     continue                 mtx[i - 1][i] = h[i]                 mtx[i][i - 1] = h[i]             return mtx         except Exception as e:             raise     def __gauss_jordan(self, matrix):         """ Solving of simultaneous linear equations             with Gauss-Jordan's method         :param  list mtx: list of 2-D matrix         :return list   v: answers list of simultaneous linear equations         """         v = []         n = self.n - 1         try:             for k in range(n):                 p = matrix[k][k]                 for j in range(k, n + 1):                     matrix[k][j] /= p                 for i in range(n):                     if i == k:                         continue                     d = matrix[i][k]                     for j in range(k, n + 1):                         matrix[i][j] -= d * matrix[k][j]             for row in matrix:                 v.append(row[-1])             return v         except Exception as e:             raise     def __calc_a(self, v):         """ A calculation         :param  list v: v-values         :return list  : a-values         """         try:             return [                 (v[i + 1] - v[i])               / (6 * (self.xs[i + 1] - self.xs[i]))                 for i in range(self.n)             ]         except Exception as e:             raise     def __calc_b(self, v):         """ B calculation         :param  list v: v-values         :return list  : b-values         """         try:             return [v[i] / 2.0 for i in range(self.n)]         except Exception as e:             raise     def __calc_c(self, v):         """ C calculation         :param  list v: v-values         :return list  : c-values         """         try:             return [                 (self.ys[i + 1] - self.ys[i]) / (self.xs[i + 1] - self.xs[i]) \               - (self.xs[i + 1] - self.xs[i]) * (2 * v[i] + v[i + 1]) / 6                 for i in range(self.n)             ]         except Exception as e:             raise     def __calc_d(self):         """ D calculation         :return list: c-values         """         try:             return self.ys         except Exception as e:             raise     def __search_i(self, t):         """ Index searching         :param float t: t-value         :return  int i: index         """         i, j = 0, len(self.xs) - 1         try:             while i < j:                 k = (i + j) // 2                 if self.xs[k] < t:                     i = k + 1                 else:                     j = k             if i > 0:                 i -= 1             return i         except Exception as e:             raise class SplineInterpolation_xz:     def __init__(self, xs, zs):         """ Initialization         :param list xs: x-coordinate list of given points         :param list zs: z-coordinate list of given points         """         self.xs, self.zs = xs, zs         self.n = len(self.xs) - 1         h = self.__calc_h()         w = self.__calc_w(h)         matrix = self.__gen_matrix(h, w)         v = [0] + self.__gauss_jordan(matrix) + [0]         self.b = self.__calc_b(v)         self.a = self.__calc_a(v)         self.d = self.__calc_d()         self.c = self.__calc_c(v)     def interpolate(self, t):         """ Interpolation         :param  float t: x-value for a interpolate target         :return float  : computated y-value         """         try:             i = self.__search_i(t)             return self.a[i] * (t - self.xs[i]) ** 3 \                  + self.b[i] * (t - self.xs[i]) ** 2 \                  + self.c[i] * (t - self.xs[i]) \                  + self.d[i]         except Exception as e:             raise     def __calc_h(self):         """ H calculation         :return list: h-values         """         try:             return [self.xs[i + 1] - self.xs[i] for i in range(self.n)]         except Exception as e:             raise     def __calc_w(self, h):         """ W calculation         :param  list h: h-values         :return list  : w-values         """         try:             return [                 6 * ((self.zs[i + 1] - self.zs[i]) / h[i]                    - (self.zs[i] - self.zs[i - 1]) / h[i - 1])                 for i in range(1, self.n)             ]         except Exception as e:             raise     def __gen_matrix(self, h, w):         """ Matrix generation         :param  list   h: h-values         :param  list   w: w-values         :return list mtx: generated 2-D matrix         """         mtx = [[0 for _ in range(self.n)] for _ in range(self.n - 1)]         try:             for i in range(self.n - 1):                 mtx[i][i]     = 2 * (h[i] + h[i + 1])                 mtx[i][-1]    = w[i]                 if i == 0:                     continue                 mtx[i - 1][i] = h[i]                 mtx[i][i - 1] = h[i]             return mtx         except Exception as e:             raise     def __gauss_jordan(self, matrix):         """ Solving of simultaneous linear equations             with Gauss-Jordan's method         :param  list mtx: list of 2-D matrix         :return list   v: answers list of simultaneous linear equations         """         v = []         n = self.n - 1         try:             for k in range(n):                 p = matrix[k][k]                 for j in range(k, n + 1):                     matrix[k][j] /= p                 for i in range(n):                     if i == k:                         continue                     d = matrix[i][k]                     for j in range(k, n + 1):                         matrix[i][j] -= d * matrix[k][j]             for row in matrix:                 v.append(row[-1])             return v         except Exception as e:             raise     def __calc_a(self, v):         """ A calculation         :param  list v: v-values         :return list  : a-values         """         try:             return [                 (v[i + 1] - v[i])               / (6 * (self.xs[i + 1] - self.xs[i]))                 for i in range(self.n)             ]         except Exception as e:             raise     def __calc_b(self, v):         """ B calculation         :param  list v: v-values         :return list  : b-values         """         try:             return [v[i] / 2.0 for i in range(self.n)]         except Exception as e:             raise     def __calc_c(self, v):         """ C calculation         :param  list v: v-values         :return list  : c-values         """         try:             return [                 (self.zs[i + 1] - self.zs[i]) / (self.xs[i + 1] - self.xs[i]) \               - (self.xs[i + 1] - self.xs[i]) * (2 * v[i] + v[i + 1]) / 6                 for i in range(self.n)             ]         except Exception as e:             raise     def __calc_d(self):         """ D calculation         :return list: c-values         """         try:             return self.zs         except Exception as e:             raise     def __search_i(self, t):         """ Index searching         :param float t: t-value         :return  int i: index         """         i, j = 0, len(self.xs) - 1         try:             while i < j:                 k = (i + j) // 2                 if self.xs[k] < t:                     i = k + 1                 else:                     j = k             if i > 0:                 i -= 1             return i         except Exception as e:             raise class Graph:     def __init__(self, xs_0, ys_0, zs_0, xs_1, ys_1, zs_1):         self.xs_0, self.ys_0, self.zs_0, self.xs_1, self.ys_1, self.zs_1 = xs_0, ys_0, zs_0, xs_1, ys_1, zs_1     def plot2d(self):         try:             plt.title("2-D Spline Interpolation in XY/XZ")             plt.scatter(                 self.xs_1, self.ys_1, c = "g",                 label = "interpolated points XY", marker = "+"             )             plt.scatter(                 self.xs_0, self.ys_0, c = "r",                 label = "given points XY"             )             plt.scatter(                 self.xs_1, self.zs_1, c = "b",                 label = "interpolated points XZ", marker = "+"             )             plt.scatter(                 self.xs_0, self.zs_0, c = "k",                 label = "given points XZ"             )             plt.xlabel("x")             plt.ylabel("y,z")             plt.legend(loc = 2)             plt.grid(color = "gray", linestyle = "--")             #plt.show()             #plt.savefig("spline_interpolation.png")         except Exception as e:             raise     def plot3d(self):         ax = plt.figure().add_subplot(projection='3d')         x = self.xs_1         y = self.ys_1         z = self.zs_1         ax.scatter(x, y, z, c='b', label='Interpolated points')         ax.scatter(X, Y, Z, c='r', label='Given points')         # Make legend, set axes limits and labels         ax.legend()         ax.set_xlim(min(X),max(X))         ax.set_ylim(min(Y),max(Y))         ax.set_zlim(min(Z),max(Z))         ax.set_xlabel('X')         ax.set_ylabel('Y')         ax.set_zlabel('Z')         # Customize the view angle so it's easier to see that the scatter points lie         # on the plane y=0         ax.view_init(elev=20., azim=-35)         plt.show() if __name__ == '__main__':     # (N + 1) points     X = [0.0, 2.0, 3.0, 5.0, 7.0, 8.0]     Y = [0.8, 2.8, 3.2, 1.9, 4.5, 2.5]     Z = [-0.5, 1.8, 2.2, 0.9, 3.5, -1.5]     S   = 0.1        # Step for interpolation     S_1 = 1 / S      # Inverse of S     xs_g, ys_g, zs_g = [], [], []  # List for graph     try:         # 3-D spline interpolation         si = SplineInterpolation_xy(X, Y)         for x in [x / S_1 for x in range(int(X[0] / S), int(X[-1] / S) + 1)]:             y = si.interpolate(x)             print("{:8.4f}, {:8.4f}".format(x, y))             xs_g.append(x)             ys_g.append(y)         si = SplineInterpolation_xz(X, Z)         for x in [x / S_1 for x in range(int(X[0] / S), int(X[-1] / S) + 1)]:             z = si.interpolate(x)             print("{:8.4f}, {:8.4f}".format(x, z))             zs_g.append(z)         # Graph drawing         print('Graph...')         g = Graph(X, Y, Z, xs_g, ys_g, zs_g)         g.plot2d()         g.plot3d()     except Exception as e:         traceback.print_exc()         sys.exit(1)
gives me this:
Which looks ok.
2 years 3 weeks ago - 2 years 3 weeks ago #311723 by Aciera
Note that the interpolation code can only handle point lists with increasing X coordinate values.
2 years 3 weeks ago - 2 years 3 weeks ago #311727 by Aciera
Modified the script to accept any sequence of point coordinates (x,y,z) read from a file called 'points_input.txt' in the same directory as the '3dSpline.py' script and outputs the interpolated points to a file called 'output_file.txt':
 #! /usr/local/bin/python3.6 """ 3-D spline interpolation (with graph drawing by matplotlib) """ import matplotlib.pyplot as plt import sys import os import traceback class SplineInterpolation:     def __init__(self, ts, ds):         """ Initialization         :param list ts: item number list of given points         :param list ds: coordinate list of given points         """         self.ts, self.ds = ts, ds         self.n = len(self.ts) - 1         h = self.__calc_h()         w = self.__calc_w(h)         matrix = self.__gen_matrix(h, w)         v = [0] + self.__gauss_jordan(matrix) + [0]         self.b = self.__calc_b(v)         self.a = self.__calc_a(v)         self.d = self.__calc_d()         self.c = self.__calc_c(v)     def interpolate(self, t):         """ Interpolation         :param  float t: value for a interpolate target         :return float  : computated y-value         """         try:             i = self.__search_i(t)             return self.a[i] * (t - self.ts[i]) ** 3 \                  + self.b[i] * (t - self.ts[i]) ** 2 \                  + self.c[i] * (t - self.ts[i]) \                  + self.d[i]         except Exception as e:             raise     def __calc_h(self):         """ H calculation         :return list: h-values         """         try:             return [self.ts[i + 1] - self.ts[i] for i in range(self.n)]         except Exception as e:             raise     def __calc_w(self, h):         """ W calculation         :param  list h: h-values         :return list  : w-values         """         try:             return [                 6 * ((self.ds[i + 1] - self.ds[i]) / h[i]                    - (self.ds[i] - self.ds[i - 1]) / h[i - 1])                 for i in range(1, self.n)             ]         except Exception as e:             raise     def __gen_matrix(self, h, w):         """ Matrix generation         :param  list   h: h-values         :param  list   w: w-values         :return list mtx: generated 2-D matrix         """         mtx = [[0 for _ in range(self.n)] for _ in range(self.n - 1)]         try:             for i in range(self.n - 1):                 mtx[i][i]     = 2 * (h[i] + h[i + 1])                 mtx[i][-1]    = w[i]                 if i == 0:                     continue                 mtx[i - 1][i] = h[i]                 mtx[i][i - 1] = h[i]             return mtx         except Exception as e:             raise     def __gauss_jordan(self, matrix):         """ Solving of simultaneous linear equations             with Gauss-Jordan's method         :param  list mtx: list of 2-D matrix         :return list   v: answers list of simultaneous linear equations         """         v = []         n = self.n - 1         try:             for k in range(n):                 p = matrix[k][k]                 for j in range(k, n + 1):                     matrix[k][j] /= p                 for i in range(n):                     if i == k:                         continue                     d = matrix[i][k]                     for j in range(k, n + 1):                         matrix[i][j] -= d * matrix[k][j]             for row in matrix:                 v.append(row[-1])             return v         except Exception as e:             raise     def __calc_a(self, v):         """ A calculation         :param  list v: v-values         :return list  : a-values         """         try:             return [                 (v[i + 1] - v[i])               / (6 * (self.ts[i + 1] - self.ts[i]))                 for i in range(self.n)             ]         except Exception as e:             raise     def __calc_b(self, v):         """ B calculation         :param  list v: v-values         :return list  : b-values         """         try:             return [v[i] / 2.0 for i in range(self.n)]         except Exception as e:             raise     def __calc_c(self, v):         """ C calculation         :param  list v: v-values         :return list  : c-values         """         try:             return [                 (self.ds[i + 1] - self.ds[i]) / (self.ts[i + 1] - self.ts[i]) \               - (self.ts[i + 1] - self.ts[i]) * (2 * v[i] + v[i + 1]) / 6                 for i in range(self.n)             ]         except Exception as e:             raise     def __calc_d(self):         """ D calculation         :return list: c-values         """         try:             return self.ds         except Exception as e:             raise     def __search_i(self, t):         """ Index searching         :param float t: t-value         :return  int i: index         """         i, j = 0, len(self.ts) - 1         try:             while i < j:                 k = (i + j) // 2                 if self.ts[k] < t:                     i = k + 1                 else:                     j = k             if i > 0:                 i -= 1             return i         except Exception as e:             raise class Graph:     def __init__(self, xs_0, ys_0, zs_0, xs_1, ys_1, zs_1):         self.xs_0, self.ys_0, self.zs_0, self.xs_1, self.ys_1, self.zs_1 = xs_0, ys_0, zs_0, xs_1, ys_1, zs_1     def plot2d(self):         try:             plt.title("2-D Spline Interpolation in XY/XZ")             plt.scatter(                 self.xs_1, self.ys_1, c = "g",                 label = "interpolated points XY", marker = "+"             )             plt.scatter(                 self.xs_0, self.ys_0, c = "r",                 label = "given points XY"             )             plt.scatter(                 self.xs_1, self.zs_1, c = "b",                 label = "interpolated points XZ", marker = "+"             )             plt.scatter(                 self.xs_0, self.zs_0, c = "k",                 label = "given points XZ"             )             plt.xlabel("x")             plt.ylabel("y,z")             plt.legend(loc = 2)             plt.grid(color = "gray", linestyle = "--")             #plt.show()             #plt.savefig("spline_interpolation.png")         except Exception as e:             raise     def plot3d(self):         ax = plt.figure().add_subplot(projection='3d')         x = self.xs_1         y = self.ys_1         z = self.zs_1         ax.scatter(x, y, z, c='b', label='Interpolated points')         ax.scatter(X, Y, Z, c='r', label='Given points')         # Make legend, set axes limits and labels         ax.legend()         ax.set_xlim(min(X),max(X))         ax.set_ylim(min(Y),max(Y))         ax.set_zlim(min(Z),max(Z))         ax.set_xlabel('X')         ax.set_ylabel('Y')         ax.set_zlabel('Z')         # Customize the view angle so it's easier to see that the scatter points lie         # on the plane y=0         ax.view_init(elev=20., azim=-35)         plt.show() if __name__ == '__main__':     # (N + 1) points     T,X,Y,Z = [],[],[],[]     fileName  = './points_input.txt'     import csv     with open(fileName, 'r') as f:         reader = csv.reader(f)         point_data = list(reader)         for line in point_data:             X.append(float(line[0]))             Y.append(float(line[1]))             Z.append(float(line[2]))     print('X:', X)     print('Y:', Y)     print('Z:', Z)     n=0     for x in X:         T.append(n+1.0)            n += 1     print('T: ', T)              #T = [1.0,2.0,3.0,4.0,5.0,6.0]     #X = [0.0, 2.0, 3.0, 5.0, 7.0, 8.0]     #Y = [0.8, 2.8, 3.2, 1.9, 4.5, 2.5]     #Z = [-0.5, 1.8, 2.2, 0.9, 3.5, -1.5]     S   = 0.1        # Step for interpolation     S_1 = 1 / S      # Inverse of S     xs_g, ys_g, zs_g = [], [], []  # List for graph     try:         # 3-D spline interpolation         si = SplineInterpolation(T, X)         for t in [t / S_1 for t in range(int(T[0] / S), int(T[-1] / S) + 1)]:             x= si.interpolate(t)             #print("{:8.4f}, {:8.4f}".format(t, x))             xs_g.append(x)                 si = SplineInterpolation(T, Y)         for t in [t / S_1 for t in range(int(T[0] / S), int(T[-1] / S) + 1)]:             y = si.interpolate(t)             #print("{:8.4f}, {:8.4f}".format(t, y))             ys_g.append(y)         si = SplineInterpolation(T, Z)         for t in [t / S_1 for t in range(int(T[0] / S), int(T[-1] / S) + 1)]:             z = si.interpolate(t)             #print("{:8.4f}, {:8.4f}".format(t, z))             zs_g.append(z)         # Write output to file         file_out = 'output_file.txt'         print('Writing output to ',file_out)         n=0         output = open(file_out, 'w')         for x in xs_g:             string=("G0 X{:8.4f} Y{:8.4f} Z{:8.4f}\n".format(xs_g[n], ys_g[n], zs_g[n]))             output.write(string)             n += 1         # Closing file         output.close()         # Graph drawing         g = Graph(X, Y, Z, xs_g, ys_g, zs_g)         g.plot2d()         g.plot3d()     except Exception as e:         traceback.print_exc()         sys.exit(1)
The 'points_input.txt' for the example below:
[code]583.8160, 2785.3929, -80.0100, 569.5160, 2551.3630, -20.8590, 569.5160, 2551.3630, -534.4340,    569.5160, 2551.3630, -563.0960,    587.9240, 2551.3630, -562.6310,    602.8020, 2531.2934, -547.8260,    616.4620, 2550.4623, -563.0180,    630.8120, 2550.4623, -563.9780,    601.7700, 1631.0440, -563.0410,    586.6920, 1633.2648, -561.9940,    574.5840, 1656.0775, -546.8950,    560.3560, 1634.1061, -561.9290,    545.8120, 1634.7045, -562.6420,    575.0200, 2556.2819, -563.3090,    575.0200, 2556.2819, -543.9050,
which gives me this output:
  [/code]
And the 'output_file.txt' content created:
G0 X583.8160 Y2785.3929 Z-80.0100 G0 X581.9705 Y2755.7769 Z-55.4991 G0 X580.1501 Y2726.5375 Z-32.1152 G0 X578.3801 Y2698.0512 Z-10.9853 G0 X576.6857 Y2670.6945 Z  6.7635 G0 X575.0920 Y2644.8440 Z 20.0042 G0 X573.6242 Y2620.8762 Z 27.6098 G0 X572.3075 Y2599.1676 Z 28.4534 G0 X571.1671 Y2580.0949 Z 21.4077 G0 X570.2282 Y2564.0345 Z  5.3460 G0 X569.5160 Y2551.3630 Z-20.8590 G0 X569.0447 Y2542.3144 Z-57.7799 G0 X568.7852 Y2536.5528 Z-103.7722 G0 X568.6972 Y2533.5994 Z-156.6372 G0 X568.7407 Y2532.9760 Z-214.1762 G0 X568.8756 Y2534.2037 Z-274.1904 G0 X569.0617 Y2536.8043 Z-334.4811 G0 X569.2589 Y2540.2990 Z-392.8496 G0 X569.4271 Y2544.2094 Z-447.0970 G0 X569.5262 Y2548.0569 Z-495.0248 G0 X569.5160 Y2551.3630 Z-534.4340 G0 X569.3714 Y2553.7511 Z-563.7128 G0 X569.1269 Y2555.2528 Z-583.5966 G0 X568.8320 Y2556.0013 Z-595.4073 G0 X568.5363 Y2556.1302 Z-600.4671 G0 X568.2892 Y2555.7728 Z-600.0982 G0 X568.1403 Y2555.0627 Z-595.6226 G0 X568.1390 Y2554.1332 Z-588.3625 G0 X568.3348 Y2553.1178 Z-579.6400 G0 X568.7773 Y2552.1499 Z-570.7771 G0 X569.5160 Y2551.3630 Z-563.0960 G0 X570.5842 Y2550.8590 Z-557.6393 G0 X571.9506 Y2550.6142 Z-554.3315 G0 X573.5678 Y2550.5734 Z-552.8176 G0 X575.3883 Y2550.6814 Z-552.7427 G0 X577.3646 Y2550.8830 Z-553.7517 G0 X579.4494 Y2551.1230 Z-555.4896 G0 X581.5952 Y2551.3462 Z-557.6015 G0 X583.7545 Y2551.4974 Z-559.7324 G0 X585.8800 Y2551.5214 Z-561.5272 G0 X587.9240 Y2551.3630 Z-562.6310 G0 X589.8486 Y2550.9707 Z-562.7790 G0 X591.6530 Y2550.3078 Z-562.0676 G0 X593.3460 Y2549.3412 Z-560.6834 G0 X594.9361 Y2548.0378 Z-558.8128 G0 X596.4320 Y2546.3645 Z-556.6426 G0 X597.8424 Y2544.2884 Z-554.3592 G0 X599.1760 Y2541.7762 Z-552.1493 G0 X600.4413 Y2538.7951 Z-550.1994 G0 X601.6471 Y2535.3118 Z-548.6961 G0 X602.8020 Y2531.2934 Z-547.8260 G0 X603.9177 Y2526.8028 Z-547.7237 G0 X605.0178 Y2522.2873 Z-548.3158 G0 X606.1291 Y2518.2901 Z-549.4772 G0 X607.2782 Y2515.3547 Z-551.0824 G0 X608.4918 Y2514.0242 Z-553.0061 G0 X609.7966 Y2514.8420 Z-555.1232 G0 X611.2194 Y2518.3514 Z-557.3082 G0 X612.7867 Y2525.0958 Z-559.4358 G0 X614.5254 Y2535.6183 Z-561.3809 G0 X616.4620 Y2550.4623 Z-563.0180 G0 X618.6015 Y2569.6655 Z-564.2510 G0 X620.8617 Y2591.2429 Z-565.1000 G0 X623.1386 Y2612.7039 Z-565.6142 G0 X625.3283 Y2631.5580 Z-565.8430 G0 X627.3268 Y2645.3144 Z-565.8355 G0 X629.0301 Y2651.4827 Z-565.6410 G0 X630.3342 Y2647.5723 Z-565.3088 G0 X631.1352 Y2631.0924 Z-564.8881 G0 X631.3291 Y2599.5526 Z-564.4280 G0 X630.8120 Y2550.4623 Z-563.9780 G0 X629.5179 Y2482.4155 Z-563.5794 G0 X627.5335 Y2398.3451 Z-563.2423 G0 X624.9835 Y2302.2688 Z-562.9691 G0 X621.9925 Y2198.2040 Z-562.7621 G0 X618.6853 Y2090.1684 Z-562.6236 G0 X615.1865 Y1982.1797 Z-562.5561 G0 X611.6209 Y1878.2552 Z-562.5617 G0 X608.1131 Y1782.4128 Z-562.6428 G0 X604.7879 Y1698.6698 Z-562.8018 G0 X601.7700 Y1631.0440 Z-563.0410 G0 X599.1548 Y1582.4611 Z-563.3543 G0 X596.9208 Y1551.4794 Z-563.7023 G0 X595.0174 Y1535.5657 Z-564.0372 G0 X593.3939 Y1532.1864 Z-564.3110 G0 X591.9996 Y1538.8083 Z-564.4760 G0 X590.7838 Y1552.8978 Z-564.4844 G0 X589.6959 Y1571.9216 Z-564.2881 G0 X588.6850 Y1593.3463 Z-563.8396 G0 X587.7006 Y1614.6385 Z-563.0908 G0 X586.6920 Y1633.2648 Z-561.9940 G0 X585.6189 Y1647.2323 Z-560.5268 G0 X584.4829 Y1656.7102 Z-558.7692 G0 X583.2962 Y1662.4082 Z-556.8264 G0 X582.0709 Y1665.0362 Z-554.8039 G0 X580.8189 Y1665.3038 Z-552.8070 G0 X579.5525 Y1663.9208 Z-550.9411 G0 X578.2837 Y1661.5969 Z-549.3115 G0 X577.0247 Y1659.0419 Z-548.0238 G0 X575.7874 Y1656.9655 Z-547.1831 G0 X574.5840 Y1656.0775 Z-546.8950 G0 X573.4199 Y1656.8530 Z-547.2291 G0 X572.2735 Y1658.8288 Z-548.1125 G0 X571.1167 Y1661.3070 Z-549.4367 G0 X569.9212 Y1663.5899 Z-551.0932 G0 X568.6588 Y1664.9796 Z-552.9732 G0 X567.3014 Y1664.7782 Z-554.9684 G0 X565.8206 Y1662.2880 Z-556.9701 G0 X564.1882 Y1656.8112 Z-558.8699 G0 X562.3761 Y1647.6498 Z-560.5590 G0 X560.3560 Y1634.1061 Z-561.9290 G0 X558.1230 Y1616.0128 Z-562.8998 G0 X555.7654 Y1595.3251 Z-563.5050 G0 X553.3949 Y1574.5286 Z-563.8068 G0 X551.1229 Y1556.1090 Z-563.8672 G0 X549.0612 Y1542.5520 Z-563.7486 G0 X547.3213 Y1536.3432 Z-563.5128 G0 X546.0148 Y1539.9684 Z-563.2222 G0 X545.2534 Y1555.9132 Z-562.9387 G0 X545.1486 Y1586.6634 Z-562.7246 G0 X545.8120 Y1634.7045 Z-562.6420 G0 X547.3111 Y1701.4656 Z-562.7336 G0 X549.5362 Y1784.1490 Z-562.9644 G0 X552.3336 Y1878.9001 Z-563.2803 G0 X555.5494 Y1981.8646 Z-563.6268 G0 X559.0300 Y2089.1879 Z-563.9497 G0 X562.6214 Y2197.0156 Z-564.1946 G0 X566.1699 Y2301.4934 Z-564.3073 G0 X569.5217 Y2398.7666 Z-564.2335 G0 X572.5230 Y2484.9810 Z-563.9188 G0 X575.0200 Y2556.2819 Z-563.3090 G0 X576.8955 Y2609.7702 Z-562.3646 G0 X578.1788 Y2646.3675 Z-561.1056 G0 X578.9356 Y2667.9505 Z-559.5671 G0 X579.2317 Y2676.3960 Z-557.7840 G0 X579.1330 Y2673.5808 Z-555.7912 G0 X578.7053 Y2661.3818 Z-553.6236 G0 X578.0143 Y2641.6755 Z-551.3163 G0 X577.1259 Y2616.3390 Z-548.9041 G0 X576.1058 Y2587.2488 Z-546.4220 G0 X575.0200 Y2556.2819 Z-543.9050
The following user(s) said Thank You: Todd Zuercher
2 years 3 weeks ago - 2 years 3 weeks ago #311748 by Aciera
Just as an explanation.
The script basically calculates a spline for each axis separately (ie one of X, one for Y and one for Z). The resulting 3D curve is the combination of the individual x,y,z values at a given iteration index (t):
Time to create page: 0.190 seconds
