Gscreen - a GTK / Glade / Python based screen
14 years 3 weeks ago #25035 by cmorley
save and quit and cancel would be better I think.
or apply and quit.
It should tell you if you have changed but not saved too...
I am working on a different display if the config is for a lathe. it just leaves out the info not pertinent to lathes.
I dont use tool tables so suggestions are welcome.
14 years 3 weeks ago #25036 by cmorley
The again if the editor is embedded in say gscreen quit doesn't make sense....
Ill finish what I got then think on it...
14 years 3 weeks ago #25037 by BigJohnT
Save & Close perhaps... but I understand where your coming from as it sounds like it might quit the CNC app as well as the editor. So maybe
Save Changes and close Editor |Yes| the button being the yes part or make it editable. In any case I can only see two actions needed, perhaps three actions... save and close the editor, revert changes, cancel the edit... nothing else makes sense to me.
14 years 3 weeks ago #25038 by BigJohnT
Oh, by embedded like in a tab? Then unsaved changes warning, a revert button and a save button is all that I can see you needing.
14 years 3 weeks ago #25074 by cmorley
buttons for add and delete (a tool)
button for apply changes
button for do not apply
One may need a refresh button since changes to the tool table can happen from mdi / program.
either that or have tool edit gtk poll linuxcnc
14 years 3 weeks ago #25078 by BigJohnT
Yep I forgot add and delete. Can you poll linuxcnc when a tab is selected? I never could figure out what triggers signals were associated with selecting a tab.
Time to create page: 0.827 seconds
