Gscreen - a GTK / Glade / Python based screen
13 years 11 months ago #26713 by cncbasher
yea I think having try'd this John has somewhere the right approach for the spindle
need to cut down the sequence or multi use the buttons
more along the lines of select fwd or rev , (start at is preselected anyhow in preferences and probably wont be touched ) then spindle button becomes the start / stop ( label spindle as spindle start & spindle stop with dual colour blue /red etc
once running fwd /rev becomes + - speed control increase / decrease , only pressing spindle stop , stops the spindle ,and allows you to change direction
this gets us down to 2 button presses to start with i.e fwd /rev and spindle start in most cases , after the first initial start the direction would be already set , so only spindle start would be needed .
the preset button could be as John says pulls up a start up spindle speed which overrides the minimum , which has to be only entered before spindle start , once spindle start is pressed you can only increase / decrease speed or stop
i'd also have on gscreen start up if the machine is not homed , then everything is greyed out until it is , and only homing is allowed , perhaps a message ticker to say ' homing required , movement disabled ' perhaps
or have I missed something !
13 years 11 months ago #26714 by BigJohnT
For the homing I would only force homing if an ini entry said to. But the first thing normally done is homing so that should be what comes up when you start not the mist flood ones.
13 years 11 months ago #26716 by cncbasher
only means John whilst your waiting to figure out why the axis will not run and your getting covered in Coolant , after a few mins you remember to home the machine first .
perhaps the ! alarm could remind you to home first , but yes some form of machine not homed indication is needed , if homing is required and of course set in the ini
yes I agree the sequence of what is shown is perhaps becoming out of sync , and the complexity increases .. either way it's commendable that Chris has brought it to this level , it's becoming usable now
great work Chris .
13 years 11 months ago - 13 years 11 months ago #26726 by cmorley
Hey for the people interested in rolling there own screens - Gscreen can now load really custom screens:
This is gaxis.
It's a screen that Pavel sent me once.
It's now a sample screen in sim/gscreen_custom/gscreen_axis.ini
Last edit: 13 years 11 months ago by cmorley.
13 years 11 months ago #26727 by cmorley
I will work on the spindle buttons some more.
Every thing your saying is making sense so stay tuned... I think i'll get it :)
Chris M
13 years 11 months ago #26731 by cmorley
K I pushed spindle control change and default to homing buttons
Chris M
Time to create page: 0.152 seconds
