Gscreen - a GTK / Glade / Python based screen
13 years 11 months ago #26502 by cmorley
Do you generally start at the same RPM range all the time or its always very different?
The +- keys are a quick way to adjust the RPM as long as its starts close to the Range you want.
I made some changes that I may push - not exactly as we described.
For whatever reason I prefer to select the direction without starting the spindle -don't ask me why...
hmm maybe i should try your way on the custom gcreen ... good practice
Chris M
13 years 11 months ago #26503 by cmorley
The one thing you will miss with Gscreen is ncggui it at the moment is not embeddable.
Bug the authour about that.
13 years 11 months ago #26504 by cmorley
Do you think user selectable spindle increase increments would be a good idea?
selectable in the preference page?
13 years 11 months ago #26505 by BigJohnT
cmorley wrote: Do you generally start at the same RPM range all the time or its always very different?
Chris M
When I manually start the spindle on the mill it is always at the same RPM to use the edge finder... when I make a probe that might change.
If the Spindle button is a toggle for off and on and Fwd and Rev just select direction that works for me too.
13 years 11 months ago #26506 by BigJohnT
cmorley wrote: The one thing you will miss with Gscreen is ncggui it at the moment is not embeddable.
Yuck... guess we need to make our own.
13 years 11 months ago - 13 years 11 months ago #26507 by BigJohnT
cmorley wrote: Do you think user selectable spindle increase increments would be a good idea?
That and a minimum spindle speed. Most spindles have a minimum speed that they can be run at.
Last edit: 13 years 11 months ago by BigJohnT.
Time to create page: 0.551 seconds
