Gscreen - a GTK / Glade / Python based screen
13 years 11 months ago #26508 by cncbasher
Chris ,
yes I think setting a minimum spindle speed and then an increment for speed steps in preferences is fine
13 years 11 months ago #26509 by BigJohnT
The mode button would be a lot more intutitive if it said MDI Mode, Auto Mode etc instead of Mode 0.
I'm actually running the 3-d chips file now on the mill...
13 years 11 months ago #26510 by cmorley
I'm not sure how long ago you pulled..
I added a setting for spindle start rpm on the preference page. This is the rpm that the spindle will automatically start at when you first push the + button. ( of course you can directly enter an RPM using the set-rpm button and the entry widget)
It's not a minimum setting as you can use the - button to lower the RPM down to 100. This is an internal linuxcnc setting.
I could add a minimum preference and an increment preference ( keeping in mind this is just in manual mode)
I will push the mode button changes in a moment...
13 years 11 months ago #26512 by BigJohnT
I pulled a couple of hours ago... I'm using DISPLAY = gscreen
The entry widget is capped at 1000 :(
13 years 11 months ago #26513 by cmorley
oops what would 9999 RPM b enough?
13 years 11 months ago #26514 by BigJohnT
More than enough for me. Are you going to add a button in the spindle block to set the S speed? If so that's better than having to go all over the place to do something and drop the decimal for spindle speed. Having to double tap a button is not very reliable for me even with this expensive ELO screen.
Time to create page: 0.433 seconds
