Gscreen - a GTK / Glade / Python based screen
13 years 10 months ago #27855 by cmorley
Replied by cmorley on topic Gscreen - a GTK / Glade / Python based screen
thanks guys I'll be around for a couple more days...
tjamscad you must download the 'master' version of linuxcnc. The easiest way is probably the buildbot see here: buildbot.linuxcnc.org/
then you can test Gscreen using the sample configurations they are under sim/gscreen or sim/gscreen_custom (you'll find the list when you start linuxcnc)
If you want to try the exact screen I have been showing pics of the you need download a couple files and add then to the config folder...
I will zip them up .....
Chris M
13 years 10 months ago #27857 by cmorley
here are the custom Gscreen files. unzip the folder and place the _individual_ files in the sim/gscreen_custom folder.
13 years 10 months ago #27858 by cmorley
If you want to try the custom Onboard keyboard layout unzip this folder in your home file:
Then when you start onboard (you can do this by typing 'onboard' in a terminal screen) you will see an icon in the top panel
click it, click preferences, select layouts, and you should see cnc - pick it.
then this will be the layout that pops up each time.
Chris M
13 years 10 months ago #27865 by andypugh
Replied by andypugh on topic Gscreen - a GTK / Glade / Python based screen
cmorley wrote: Development will stop shortly for holiday to UK
Where are you going to be?
You can develop in my garage if you get withdrawal symptoms :-)
13 years 10 months ago #27878 by cmorley
flying into London for a day then to Liverpool for a week or so...
I'm sure I will get some withdrawals.....!
Where are you Andy?
13 years 10 months ago #27908 by tjamscad
Replied by tjamscad on topic Gscreen - a GTK / Glade / Python based screen
Chris,
I have installed LinuxCNC and tried gscreen. LinuxCNC will not load for me. I have seen you keyboard and would like to install it on a machine for an operator to use. I am runnig Ubuntu 12.04 I am just running sim.
