Gscreen - a GTK / Glade / Python based screen
13 years 8 months ago #30262 by cmorley
newbynobi wrote: Chris,
I just noted that clicking on the header of Tool# and Pocket# in tooledit widget will change the order, sort them.
Would it be possible to make this also for the diameter column?
I have at the moment only 23 tools in my tool file, but on my working machine I have about 50 tools, so searching for a certain tool diameter, i.e. a 3,2 mm drill would be easier.
Norbert
Yes I will add that.
13 years 8 months ago #30263 by cmorley
Sample of bottom buttons for industrial:
The following user(s) said Thank You: BigJohnT, tjamscad
13 years 8 months ago #30265 by newbynobi
Can you post a sample of the program?
I know M2 is never highlighted, I bet it depends on the program.
I could add highlight color as selectable.
Hallo Chris, that is not a matter of M2. It is just because in hal_sourceview in highlight_line
you use scroll_to_mark with use_allign = True, so the highlighted line is every Time in the middle of the box.
Norbert
13 years 8 months ago #30266 by newbynobi
Then we are not talking the same thing.
I am talking of a complete tool change.
When I did cnc work the tool setting and origin setting were done in manual mode so you could jog.
so this requires tool changing to set each tool or to touch off the origin with the right tool.
I ran a lathe but I would think a mill would be similar.
Chris M
That is done very similar on a mill.
So your point of view is right.
What about my idea, adding a change button to the tool_edit widget, called change, so you can change a tool, without knowing the number, because you have all necessary information in front of your eyes!
Norbert
13 years 8 months ago #30269 by newbynobi
Hay Chris,
by the way, what theme are you using, I like the round button and the metal finish.
Norbert
13 years 8 months ago #30270 by cmorley
An interesting idea. It still doesn't fix the mode switching problem.
I have enough work as it is ! :)
Time to create page: 0.423 seconds
