Gscreen - a GTK / Glade / Python based screen
13 years 8 months ago #30272 by cmorley
newbynobi wrote: Hay Chris,
by the way, what theme are you using, I like the round button and the metal finish.
Norbert
I think it's this one:
art.gnome.org/themes/gtk2/213
h20-gtk2-saphire
13 years 8 months ago #30273 by newbynobi
If you add it to your ToDo list, than I would be glad for now :)
13 years 8 months ago #30282 by karlkec
cmorley wrote: The jogging mode problem, is really a mode switching problem.
This like origin shift, origin zero, tool index, coordinate shift are actual done with MDI commands.
it's reliably switching back to manual mode (jogging requires this) that is the problem.
I'm fairly stumped right now. Tool index is different from say origin shift.
Tool index needs to wait till a HAL pin changes and this waiting screws me up.
Hi Chris,
Is it a problem of knowing when to tell it to switch back to manual mode? Have you tried polling halui.program.is-idle? Or maybe you aren't using halui. Have you looked to see how touchy does this?
I'm full of questions but no answers. ;)
Karl
13 years 8 months ago - 13 years 8 months ago #30287 by tjamscad
cmorley wrote: Sample of bottom buttons for industrial:
I like it, I like it :)
Chris,
I asume this is still concept at this point?
Last edit: 13 years 8 months ago by tjamscad.
13 years 8 months ago - 13 years 8 months ago #30290 by BigJohnT
I like that!
Is it in master?
Does it work with pyngcgui?
Last edit: 13 years 8 months ago by BigJohnT.
13 years 8 months ago #30294 by cmorley
I have not pushed this yet, I am removing the entry box. which involves a fair bit of code.
I hope it's not a mistake....
maybe I should push with the entry box still there first??
As pyngcgui is embedable, there is no reason it shouldn't work. The reason I haven't tried it is pyngcgui is in V2.5 and Gscreen in master. so it's a bit of work to try it. I have been busy with other things.
Chris M
Time to create page: 0.464 seconds
