- Thank you received: 394
2. If an axis moves such that another digit is needed in the DRO display, it seems the width of the axis select buttons and width of the <Absolute> and <Relative> columns change to balance things horizontally. This works nicely unless the axis is sitting at a transition point. For instance, if it's at 10.0000, servo and encoder uncertainty can make it jump back and forth between 9.9999 and 10.0000. The constant changing in width of the axis select buttons and the <Relative> and <Absolute> columns is a bit annoying. Could these columns be made fixed width yet allow room for the largest expected DRO values?
cmorley wrote: It is a sample and has not been pushed - is that all right looking?
I am working on the restart entry widget - I just noticed you can't enter a line number.
i will have it pop up with the last run line.
Chris M
