Gscreen - a GTK / Glade / Python based screen
13 years 7 months ago #30770 by ditechcnc
13 years 7 months ago #30784 by cmorley
Thanks for the report and the error pinpointing.
I pushed the fix.
Chris M
13 years 7 months ago #30787 by cmorley
ok you can add 'continuous' to the DISPLAY INCREMENTS section in any order.
hopefully the DRO in industrial is a little more stable.
The restart dialog has a numerical entry and pops up with the last line number run. you can type directly into the dialog and move it.
industrial has home indicators and DTG. The indicators only pop up when all the axis are homed, that should be changed.
Chris M
13 years 7 months ago #30809 by emcPT
I was trying to get Gscreen running just for simulation while I am preparing my lathe and I could not.
I have installed from the buildbot the sim version:
LINUXCNC - 2.6.0-pre0-3890-g5075862
I can run others simulations including axis, so I think I did not mess anything. Not sure if I am helping in reporting this, but here it goes.
All tests with all the possible configurations of gscreen returned an error:
Machine configuration directory is '/home/me/linuxcnc/configs/sim/gscreen'
Machine configuration file is 'gscreen_lathe.ini'
Starting LinuxCNC...
redis server started as: 'redis-server ', logging to: /dev/null
io started
halcmd loadusr io started
Could not open command file 'core_sim.hal'
Cleanup done
and the debug file contains:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
Can not find -sec REDIS -var DISABLE_SERVER -num 1
Can not find -sec REDIS -var SERVER_PATH -num 1
Can not find -sec REDIS -var SERVER_ARGS -num 1
Can not find -sec REDIS -var SERVER_LOG -num 1
16279
PID TTY STAT TIME COMMAND
16278
16278 pts/0 Dl+ 0:00 redis-server
Stopping realtime threads
Unloading hal components
13 years 7 months ago - 13 years 7 months ago #30812 by cmorley
sim/axis9 works?
can you look in configs/sim folder and see if
core_sim.hal
is there?
If it isn't then sim/axis shouldn't work either.
Chris M
Last edit: 13 years 7 months ago by cmorley.
13 years 7 months ago - 13 years 7 months ago #30814 by cmorley
I think this is a problem with the system links.
I only have worked with Gcsreen as a Run-in-place build.
by using buildbot it's an installed build which moves a few things around.
There are system-links (shortcuts) that are pointing to the wrong place.
Where ever sim/axis/core_sim.hal is pointing to
sim/gscreen/core_sim.hal must point to
There are probably a couple others too. hal_manual_toolchange.hal etc
Chris M
Or maybe the system links are missing when copied into your linuxcnc folder...
Time to create page: 0.136 seconds
