- Thank you received: 394
newbynobi wrote: No, I tried this in normal gscreen. I noticed this while testing around with gmoccapy and I thought it was caused by myself. But testing it with gscreen results in the same behavior.
If I leave gscreen with a visible cursor, I am able to restart gscreen from the terminal without any problem, just when the cursor was hideen when closing gscreen, the server crashes.
How can I find out what hapens?
Norbert
newbynobi wrote: Hallo Chris,
I found another thing, we should change.
You have a spindle_bar on your screen, so do I.
Shouldn't there be a INI Section for the min and max values to set to the widget?
Otherwise the user must change code to set the coresponding values.
I recommend and [SPINDLE] Section in the INI with
MIN_VEL =
MAX_VEL =
What do you think?
Norbert
newbynobi wrote:
Hallo Chris,
MIN_VEL =
MAX_VEL =
What do you think?
Norbert
This would seem convenient for the user. You can change this now by editing the GLADE file.
though it should be in the [DISPLAY] section
What is min_vel for?
The display should always show 0 as a minimum, don't you think?
Chris M
