Gscreen - a GTK / Glade / Python based screen
13 years 7 months ago #31045 by karlkec
cmorley wrote: ok fixed some things.....
Chris M
Hi Chris,
I see the homing asterisks seem to now work well. Thanks.
I was thinking about the DRO numbers. On the 3-axis mill we have a 19" screen on a swing arm. It's often several feet from the operator, and the DRO numbers are kind-of small at this distance. It's too bad since there's so much extra room in the DRO area on a 3-axis machine.
I know it's this way to accommodate 9 axes, and I agree with the reasoning. On a 3-axis machine if the rel, abs, dtg values were arranged vertically instead of horizontally (I know, I know, going backwards), I think they could be made quite a bit larger.
Thinking of other users, is there a way to separate the DRO area into its own layout file (glade?), and have different files optimized for different numbers of axes. It's a rare day that the number of axes on a machine changes, so I don't think it matters much if it requires some setup effort. I don't want to make more work for Chris, but if this is feasible I might try to tackle it myself.
Any thoughts?
Karl C
13 years 7 months ago - 13 years 7 months ago #31060 by cmorley
I assume you mean the 'industrial' screen, the default Gscreen has a slightly larger DRO.
There is no need to have a separate second GLADE file for different DRO layouts - you edit the existing GLADE file to what you want.
In fact this is what Industrial is - a customized Gscreen GLADE file.
Now some things you change you must change the python code that controls it. Industrials 'tab' buttons are an example.
Other things -such as the DRO are quite flexible without Python code.
For instance to make the DRO larger you can change the attributes of each of the HAL_DRO widgets.
attributes control color size/scale, weight, style etc
As long as you keep the same names of the HAL_DRO widgets you can move them around.
If you have a machine that never will use the UVW DRO widgets, you can erase them.
Using Glade takes some time to get used too - It's not exactly what-you-see-is-what-you-get.
If you are using RIP build you must be in that environment and launch GLADE from the terminal so it is aware of all the HAL widgets.
If you have an installed build, it should work normally.
If you edit the sample glade file, when linuxcnc updates it will overwrite the changes.
So making a separate config would be wise.
The other side of this is if I upgrade Gscreen glade file and you wish to use it you will have to edit it again.
This will be annoying while heavy developing is happening, but after release it should be no big deal.
Chris M
It's in fact this user customization option that drove Gscreen's development. By leveraging gladeVCP's handler file code now you can build truely custom screens. Soon Norbert's Gmoccapy will be available in master - it is _really_ different from Gscreen.
Last edit: 13 years 7 months ago by cmorley.
13 years 7 months ago #31079 by newbynobi
Hallo Chris,
I got now all the confirmations about the use of the ICONS.
I will add a list to the code so everybody knows exactly where the Icons are from.
I didn't send you the code jet, because I need to clean it up a little and add more comments and will then
make some more videos to explain the configuration. I added also user Tabs, side panels
and have to make some useful panels to show how this works.
Please give me be a little bit more time.
Hope to be ready during next week.
Norbert
13 years 7 months ago #31108 by newbynobi
Hallo Chris,
I got the following problem.
I open gscreen, then I went to preferences.
I toggle "Hide Cursor" and the cursor is gone.
Now I go to normal mode and switch on the machine, then go back to preferences and close
gscreen by clicking the exit button.
Now try to open gscreen from the terminal again.
In my case the X-Server crashes!
Can you reproduce the behavior?
Norbert
13 years 7 months ago #31116 by cmorley
I tried this in industrial and it seems to work fine.
Were you using industrial ?
13 years 7 months ago #31126 by newbynobi
No, I tried this in normal gscreen. I noticed this while testing around with gmoccapy and I thought it was caused by myself. But testing it with gscreen results in the same behavior.
If I leave gscreen with a visible cursor, I am able to restart gscreen from the terminal without any problem, just when the cursor was hideen when closing gscreen, the server crashes.
How can I find out what hapens?
Norbert
Time to create page: 0.096 seconds
