Touch screen setup GUI
13 years 7 months ago #31602 by beltramidave
Replied by beltramidave on topic Touch screen setup GUI
Thanks John, I was able to resolve the single click issue. The pointer does appear centered under my finger, I think that it is more that that scroll bars are so close to the edge of the screen more than anything. I have my screen resolution set to 1024 x 768.
13 years 7 months ago #31607 by BigJohnT
Replied by BigJohnT on topic Touch screen setup GUI
Yea, I've found that my fingers can't touch the edge or the touch sensitive area is not all the way to the edge...
Which GUI are you using?
13 years 7 months ago #31609 by beltramidave
Still trying to use Axis even though it has been said that it doesn't work well with the touch panels. The scroll bar issues come in when just browsing through files.t
For the most part, Axis doesn't work too bad, i don't think. I just can't wrap my head around all the programming that it takes to make changes to these programs, even after looking at all the great examples. I just wish I could figure out where/how to make basic changes to icon & button sizes used in Axis. Don't want to recreate the wheel, just make a few modifications for easier touch compatability.
Thanks for your continued help!
13 years 7 months ago #31610 by BigJohnT
Axis is a great GUI for keyboard/mouse and a terrible GUI for a touch screen. IMHO it would be a time sink to try and make Axis a good GUI for a touch screen.
While Touchy is a good touch screen GUI I find that Dewey's Touchy + Gremlin + ngcgui a very workable combination. It gives you the Gremlin backplot preview window like Axis so you can see if your program makes any sense or not. Touchy does require a couple of buttons and a MPG or similar to jog with. Once you use Touchy a bit it is easy to get the job done.
Another option is gscreen and I think it doesn't require any hardware inputs like Touchy does.
13 years 6 months ago - 13 years 6 months ago #33472 by beltramidave
John,
Could you share your config and any other info for your Elo touch screen and Evtouch driver? I followed the directions from here: help.ubuntu.com/community/EloTouchScreen .
I put the following information in my config file (like the website said) and then I was not able to to get Ubuntu to run, it locked up at the splash screen. I was able to use a LiveCD to boot and remove the config file and then all worked well again. Any ideas?
Here is the info from the config file:
Section "InputClass"
Identifier "Elo class"
MatchProduct "Elo TouchSystems"
MatchDevicePath "/dev/input/event*"
Driver "evtouch"
Option "minX" "530"
Option "minY" "570"
Option "maxX" "3500"
Option "maxY" "3500"
EndSection
Last edit: 13 years 6 months ago by beltramidave.
13 years 6 months ago #33482 by BigJohnT
That is the exact instructions that I followed to install the two touch screens I have.
When you created the config file did you use sudo so it is owned by root?
I can't see my config from here but I will post it a bit later when I go to the shop.
Time to create page: 0.350 seconds
