Touch screen setup GUI
13 years 6 months ago #33483 by beltramidave
Replied by beltramidave on topic Touch screen setup GUI
I followed the directions exactly.. I did notice that when I did "lshal | grep Elo", that I did not get any "info.product' like shown below. My main concern for doing this is that my pyvcp jog buttons and the +/- jog buttons in axis still are sticky (sometimes they keep focus and continue to jog after taking finger off the touch screen). I also have problems when trying to use the virtual keyboard.
Configuration
Ubuntu 10.04
Do NOT edit /etc/X11/xorg.conf. All touchscreen configuration should be done by changing the appropriate .conf file in /usr/lib/X11/xorg.conf.d/.
Check your device info:
lshal | grep Elo
info.vendor = 'Elo TouchSystems' (string)
usb_device.vendor = 'Elo TouchSystems' (string)
usb.vendor = 'Elo TouchSystems' (string)
info.product = 'EloTouchSystems,Inc Elo TouchSystems 2216 AccuTouch® USB Touchmonitor Interface' (string)
input.product = 'EloTouchSystems,Inc Elo TouchSystems 2216 AccuTouch® USB Touchmonitor Interface' (string)Create a configuration file to match your device:
Ubuntu 10.04:
sudo nano /usr/lib/X11/xorg.conf.d/69-evtouch.conf
Section "InputClass"
Identifier "Elo class"
MatchProduct "Elo TouchSystems"
MatchDevicePath "/dev/input/event*"
Driver "evtouch"
Option "minX" "530"
Option "minY" "570"
Option "maxX" "3500"
Option "maxY" "3500"
EndSection
13 years 6 months ago #33484 by BigJohnT
Replied by BigJohnT on topic Touch screen setup GUI
That could be two unrelated issues... how did you plug the touch screen in?
I would be concerned that you didn't get info from lshal | grep Elo...
13 years 6 months ago #33485 by beltramidave
Both usb and serial cables are connected, if that is what you mean.
13 years 6 months ago #33486 by BigJohnT
Yes, I think you only use one or the other. I'm using the USB cable on mine.
13 years 6 months ago #33487 by BigJohnT
john@BpMill:~$ lshal | grep Elo info.vendor = 'Elo TouchSystems' (string) usb_device.vendor = 'Elo TouchSystems' (string) usb.vendor = 'Elo TouchSystems' (string) info.product = 'Elo TouchSystems, Inc. Elo TouchSystems 2700 IntelliTouch(r) USB Touchmonitor Interface' (string) input.product = 'Elo TouchSystems, Inc. Elo TouchSystems 2700 IntelliTouch(r) USB Touchmonitor Interface' (string) john@BpMill:~$
Section "InputClass" Identifier "Elo class" MatchProduct "Elo TouchSystems" MatchDevicePath "/dev/input/event*" Driver "evtouch" Option "minX" "100" Option "minY" "100" Option "maxX" "4000" Option "maxY" "4000" EndSection
and make sure your in usr/lib
13 years 6 months ago #33488 by BigJohnT
Mine is an Elo ET1515L-8CWC-1-GY-G part #E700813. Some other versions of the 1515L will not work on Ubuntu or I could not get them to work.
Time to create page: 0.094 seconds
