Screen shots of gui designs
2 years 9 months ago #291451 by persei8
Replied by persei8 on topic Screen shots of gui designs
I've been updating QtDragon to the next version. There are several new features compared to the previous one, such as a sqlite database for tool data and some new utilities. If you would like to try it out, it's at  github.com/persei802/QtDragon_hd . The files here are for simulation only so you will have to provide the proper ini and hal files for your machine. If you already use QtDragon, the transition should be relatively painless. There is also a tool for assisting in creating style sheets at  github.com/persei802/Qt-Style-Designer . Please direct all queries, bug reports etc. to github, not this forum. The attached screenshot shows 1 of 4 available styles. Thank you.
Jim
The following user(s) said Thank You: tommylight, 0x2102, besriworld, chrisfairbrothern, Aciera, MennilTossFlykune
2 years 9 months ago #291488 by cmorley
Replied by cmorley on topic Screen shots of gui designs
Wow that looks nice!
Is this master only or 2.9 as well?
2 years 9 months ago #291531 by persei8
Good question. I've only ever used the master branch. However, I cloned the master branch VM and to a new VM and installed 2.9.2. Unfortunately, it appears that this qtdragon only works with 2.10. I could probably make a version that works with 2.9, but that's another project.
Jim
2 years 8 months ago - 2 years 8 months ago #293507 by MarcoGaspar
#MarkoPolo Can you share your files?
Last edit: 2 years 8 months ago by MarcoGaspar.
2 years 8 months ago #293537 by MarkoPolo
Which files do you need?
I'm guessing you want to have tool images.
Is it only in the tool view or in the tool table too?
I can share the files, but it would be good to start a new thread for this purpose.
The following user(s) said Thank You: MarcoGaspar
2 years 8 months ago #293540 by MarcoGaspar
If you can share your scrren files :D
Time to create page: 0.421 seconds
