Screen shots of gui designs
9 years 6 months ago #91755 by newbynobi
Very, very nice!!
I looked at the code and I am proud, you could use some of my code. Be sure I like very much some of your ideas and I will sure "borrow" some of the code to improve gmoccapy. I like very much the way you added keyboard and entry widgets to be used with touch screen.
May I invite you to help to improve gmoccapy?
Because of a new job, I am running very short of time:(
Norbert
The following user(s) said Thank You: KCJ
9 years 6 months ago #91770 by massimodamassa
Congratulations, is the most beautiful GUI I've ever seen, also working in lathe mode?
9 years 6 months ago #91792 by KCJ
Replied by KCJ on topic Screen shots of gui designs
Wow! Thank you all for the kind words. You have encouraged me to continue working on hazzy. Since I have essentially no programming experience I am learning as I go, which can be tough at times, but I am having a lot of fun!
Chris: It seems like there is interest so I will certainly add hazzy to the LCNC repo, when it gets to a point were it is more complete.
Norbert: I have learned almost all the Python I know by studying your code, thank your for commenting it out so well and making it neat and readable! I have a lot of projects going on right now but I will try and help with gmoccapy when I have some time. I used to use gmoccapy before I made hazzy and I liked it very much.
massimodamassa: I don't have a CNC lathe so I have not been working on a lathe mode, but it should not be too hard to add. I guess I should convert one of my lathes to LCNC, so I am forced to add a lathe mode ;)
I guess I will start a new thread for further discussion so this one does not get cluttered.
Kurt
9 years 6 months ago #91793 by massimodamassa
Basically in lathe mode you only have two axes, Z is the length and X for the diameters.
More than anything else will be the tool art management.
As soon as I have some time I want to test it and see if there are problems.
Small changes to the axis would be enough (lift what you do not need) and move some buttons, but I still do not understand how to change the original gui.
If someone is available it would be a nice thing ;-)
9 years 6 months ago #91801 by KCJ
Looks like the main thing I need to change to add lathe mode is the tooltable. Right now it only has Tool, Pocket, Diameter and Length entries. Additional entries are needed to describe lathe tools.
The GUI is fairly easy to change. All you need is Glade to be installed and you can open the hazzy.glade file and change the layout by drag and drop, more or less.
Also, I have started a new thread under "Other User Interfaces". Lets talk over there so we don't clutter this thread.
Kurt
8 years 10 months ago #102858 by cmorley
Replied by cmorley on topic Screen shots of gui designs
Demo video of a Qtvcp screen in development.
Chris M
Time to create page: 0.401 seconds
