Screen shots of gui designs
8 years 10 months ago #102898 by cmorley
Replied by cmorley on topic Screen shots of gui designs
In this sample screen I use dialogs a lot.
I could probably hide the graphics and dro and intergrate the dialogs screen there.
If I did that the darkening overlay would not be very useful - though I may be able to get it to darken every thing but the window.
The chips image in the overlay may be a bit cheesy - just trying different things.
Chris M
8 years 10 months ago #103863 by cmorley
Video shows process of building a custom screen.
Obviously not pretty or very useful but shows the process.
uses pyqt5 with python2 and the graphics widget uses native pyqt.
Now I need someone to build a really good and pretty screen...
Chris M
The following user(s) said Thank You: KCJ, pavelshakal
8 years 10 months ago #103866 by KCJ
Replied by KCJ on topic Screen shots of gui designs
Chris, great work! I can't wait to get back from vacation so I can check it out and see about making a full UI.
-Kurt
8 years 9 months ago #104352 by persei8
Replied by persei8 on topic Screen shots of gui designs
Sorry to be a PITA. I managed to download (clone) qtvcp_py2 and build and install it, but now when I run it like so:
$ linuxcnc qtdefault.ini
LINUXCNC - 2.8.0~pre1
Machine configuration directory is '/home/jim/linuxcnc/configs/sim.qtscreen'
Machine configuration file is 'qtdefault.ini'
Starting LinuxCNC...
emc/iotask/ioControl.cc 768: can't load tool table.
Found file(lib): /usr/share/linuxcnc/hallib/core_sim.hal
Note: Using POSIX realtime
Found file(lib): /usr/share/linuxcnc/hallib/sim_spindle_encoder.hal
Found file(lib): /usr/share/linuxcnc/hallib/simulated_home.hal
Found file(REL): ./check_constraints.hal
File "/usr/bin/qtscreen", line 8, in <module>
from qtvcp.core import Status
ImportError: No module named qtvcp.core
At github.com/LinuxCNC/linuxcnc/tree/770a0f...339/lib/python/qtvcp there is no clone or download button, so how do I get the qtvcp module and where does it go when I get it?
8 years 9 months ago #104360 by persei8
OK I got that resolved, but now it's:
File "/usr/bin/qtscreen", line 23, in <module>
from qtvcp import qt_makepins, qt_makegui
File "/usr/lib/python2.7/dist-packages/qtvcp/qt_makepins.py", line 24, in <module>
from qtvcp.qt_glib import QComponent
ImportError: No module named qt_glib
I resolved the first issue by creating a symlink to the linuxcnc-qt5vcp_py2 directory, but this time, there really is no module named qt_glib.
8 years 9 months ago - 8 years 9 months ago #104367 by KCJ
You probably should be building LCNC from source to use the development branches. It sounds like you might not be doing that. I can walk you thru that if needed. I am going to checkout the qt5vcp_py2 branch in a bit here myself.
EDIT:
You need to have git installed and configured. Then
git clone https://github.com/LinuxCNC/linuxcnc.git linuxcnc-dev cd linuxcnc-dev git checkout qt5vcp_py2
That will give you a directory with the qt5vcp_py2 branch, than build that as a RIP. Follow the directions here: www.wiki.eusurplus.com/index.php?title=LinuxCNC_Run_In_Place
Don't hesitate to ask if you still are having trouble.
Last edit: 8 years 9 months ago by KCJ. Reason: Forum ate the https
The following user(s) said Thank You: persei8
Time to create page: 0.502 seconds
