Thanks for reply!
I used the older version.
I tried to update the branch, but I broke it. Had to build anew.
After building, I got an error:
File "/home/ilya/linuxcnc-dev/lib/python/qtvcp/plugins/qtvcp_plugin.py", line 28, in <module>
from qtvcp.plugins.widgets_plugin import *
File "/home/ilya/linuxcnc-dev/lib/python/qtvcp/plugins/widgets_plugin.py", line 7, in <module>
from qtvcp.widgets.gcode_widget import GcodeEditor
ImportError: No module named gcode_widget
I fixed line 7 in widgets_plugin.py: Changed gcode_widget to gcode_editor
Maybe you should fix that too.
Now, I'll try to follow your prompts.
Thanks,
Ilya
_______________________________________________
The same error in the file with the file qt_cnc_handler.py
File "/home/ilya/linuxcnc-dev/share/qtscreen/skins/qt_cnc/qt_cnc_handler.py", line 11, in <module>
from qtvcp.widgets.gcode_widget import GcodeEditor as GCODE
