hazzy - Another touchscreen GUI
9 years 6 months ago #92145 by KCJ
Replied by KCJ on topic hazzy - Joint Position DROs
Rod, after rereading you posts here and on the Gmoccapy thread I think your problem may not be related to my problem above. I thought you were saying the errors were printed to the terminal, but were not displayed by Gmoccapy, but based on your screenshot on the other thread I see what you are calling the terminal is the Gmoccapy exception dialog. This displays exceptions in the code, which is not necessarily related to configuration or "machine" type error.
9 years 6 months ago #92185 by rodw
Replied by rodw on topic hazzy - Joint Position DROs
Kurt, I believe this is a LCNC error not a GUI error. I have updated my Gmoccapy thread now my network is back to normal after a UPS died at 4:00am on a public holiday. This is the error in the terminal window.
joint 3 on limit switch error emc/task/taskintf.cc 945: Error on joint 3, command number 129 task: main loop took 0.141217 seconds
I believe limit switch errors previously appeared in a GUI message window. You'd need to test in Axis GUI but I'm too far into a build to experiment right now as my config is so tightly bound to Gmoccapy. Once your GUI becomes stable and I've got my Plasma machine working, I may try building a plasma addon for your GUI.
Anyway, I'll confine the discussion to the Gmoccapy thread as Norbert has involved others in the past.
The following user(s) said Thank You: KCJ
9 years 6 months ago #92366 by TurBoss
Replied by TurBoss on topic hazzy - Joint Position DROs
I had to get a touch screen + pemndant
thanks great work
9 years 6 months ago #92367 by KCJ
Which touchscreen did you get? I am using a 15" elo IntelliTouch and love it.
I will post some pictures of my control panel so others can see how I use the GUI.
Progress Update:
I almost have a touchscreen file browser finished. It has been a lot of work but I think it will have been worth it. I will add it to the main UI in the next few days. It would be great if you could look it over and make sure I have not made too many mistakes :)
I am also working on making the UI modular so it is easy to add custom panels, I think I have some ideas for how to do that.
Thanks for all your help TurBoss!
Kurt
9 years 6 months ago #92368 by KCJ
Replied by KCJ on topic hazzy - Control Panel
Here is a picture of a the mock-up control panel currently on my mill. I have all the metal cut for making the real one, just need to get around to putting it together.
9 years 6 months ago #92398 by TurBoss
Replied by TurBoss on topic hazzy - Control Panel
I want to buy one of this
www.chalk-elec.com/?page_id=1280#!/10-un...413/category=3094861
but for the next control, now i'm using a p4 with AGP graphics so no hdmi
Time to create page: 0.095 seconds
