Hi Tommylight,
The SVG file is intact. As far as I can see, nothing has been deleted. Yes, there are a lot of layers that are switched on and off given which machine type and which panels are showing. A few layers are locked, not many. Yes, you can unlock them. In Inkscape, the layer icons are near the bottom the screen, near the left-center. They look like little eyes. The layers which are hidden are greyed. The other icon is for locking the layer.
I had hoped to work with a programmer, exporting whatever needs to be exported. As far as I know there was only one programmer interested, but then he seemed not to be interested, now I learn that he is again, well, good! I responded to that message on CNCzone.
I saw a post on CNCZone that stated someone offered to pay to have it programmed, but I wanted to what other options existed.
I want to make something clear to all: I wanted to be fairly certain that the interface design was mature enough to offer to LinuxCNC. I take the responsibility of asking anyone to do anything seriously. I stated that I would take time, and it did.
Since the beginning, I've tried to best to work this project around the drama I have in my life. I also had a stupid problem with Inkscape. There was a font issue with my laptop, and I thought there was a Inkscape compatibility problem, so I filed a bug report. As it turns out, I forgot to put OpenSans font on my latop. Duh.
Still, I did everything I stated I was going to do--except export the images from the source file, and I still aim to help with that chore, though, when I was working with Kurt, he seemed to indicate he was able to generate a lot of things such as X, Y, Z as characters instead of graphics. There were other technical problems with the arrow buttons which I might need to modify. This is a process.
As far as the exporting images from the svg source, I indeed want to make sure no other changes are at this point are requested from the programmer before the export process starts. The exporting would only take perhaps a day, but each change becomes a file version management issue, which quite frankly I am error-prone at when saving off hundreds of files. So, I have to accept my limitations. I actually have good organizing ability but if you give me anything repetitive to do, I mess it up.
I will start the bitmap export process--even if it's inefficient at this stage. I want people to be happy.
