QtPyVCP Mill Touch Screen
17 Mar 2019 13:12 - 18 Mar 2019 11:24 #128817
by BigJohnT
QtPyVCP Mill Touch Screen was created by BigJohnT
After using my BP_Touch for a while on the mill I decided to change a few things up so I started from scratch and used the new VTK backplot which is way faster to render than gremlin is. Now I'm sort of a minimalist so I don't go for the flashy GUI's but that's all done with stylesheets or in the .qss file so it does not change the GUI to add style if one wants that.
The files
github.com/jethornton/mill_touch
The Docs
jethornton.github.io/mill_touch/index.html
Some screen shots
On this tab I'm using the new container with rules to disable everything in this tab until a tool is loaded
Now with a tool loaded I can set tool offsets for the current tool
JT
The files
The Docs
Some screen shots
JT
Last edit: 18 Mar 2019 11:24 by BigJohnT.
- Thank you received: 6285
17 Mar 2019 17:29 #128838
Replied by tommylight on topic QtPyVCP Mill Touch Screen
Elegantly beautiful ! Does it come in black?
17 Mar 2019 22:53 #128861
by Leon82
Replied by Leon82 on topic QtPyVCP Mill Touch Screen
Is that the same as the vtk backplot?
I didn't see vcp backplot in the widget list
18 Mar 2019 11:22 #128881
by BigJohnT
You can have what ever color you want just change the color in the qss file
JT
Replied by BigJohnT on topic QtPyVCP Mill Touch Screen
JT
The following user(s) said Thank You: tivoi
18 Mar 2019 11:26 #128882
by BigJohnT
Sorry, that was a typo it is VTK backplot
JT
JT
The following user(s) said Thank You: Leon82
18 Mar 2019 14:24 #128901
by BigJohnT
Yes! I changed one word in the config.yml file and copied a dark qss to the ui directory.
JT
JT
18 Mar 2019 21:51 #128925
YML file ??? Me thinks you got a german keyboard !
Or is it really an yml file ? I wonder......
Thanks for everything , JT.
Yes! I changed one word in the config.yml file ..........
JT
19 Mar 2019 00:15 #128951
by BigJohnT
Yep it's a .yml file, but don't fret you can also just put a .qss stylesheet in the configuration directory and use it by adding it to the ini file with STYLESHEET = dark.qss. Wow this it getting to be so much fun...
information about .yml files is here qtpyvcp.kcjengr.com/configuration/yml_config.html
JT
JT
JT
The following user(s) said Thank You: tommylight, tivoi
19 Mar 2019 00:42 #128953
by Leon82
How did you get the on screen scale to disappear for the backplot?
19 Mar 2019 10:06 #128961
by BigJohnT
You can either toggle them on and off on the settings page or you can set the state you want in the ini file.
qtpyvcp.kcjengr.com/configuration/ini_options.html
JT
JT
