QtPyVCP Mill Touch Screen
24 Mar 2019 19:25 #129506 by rodw
Replied by rodw on topic QtPyVCP Mill Touch Screen
Well thats one way to see if people are following along :)
25 Mar 2019 02:38 #129551 by KCJ
Replied by KCJ on topic QtPyVCP Mill Touch Screen
LOL Rod!
13 Feb 2026 13:54 #342889 by Kell
Replied by Kell on topic QtPyVCP Mill Touch Screen
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.8
Machine configuration directory is '/home/ricco/linuxcnc/configs/mill_touch_sim'
Machine configuration file is 'mill_touch.ini'
INIFILE=/home/ricco/linuxcnc/configs/mill_touch_sim/mill_touch.ini
VERSION=1.1
PARAMETER_FILE=emc.var
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=
DISPLAY=qtpyvcp
COORDINATES=X Y Z
KINEMATICS=trivkins coordinates=XYZ
Starting LinuxCNC...
Found file(REL): ./mill_touch.hal
Found file(REL): ./custom.hal
Starting DISPLAY program: qtpyvcp
Can't execute DISPLAY program qtpyvcp
task: 29 cycles, min=0.000006, max=0.012605, avg=0.005740, 0 latency excursions (> 10x expected cycle time of 0.010000s)
Debug file information:
Note: Using POSIX realtime
Unexpected realtime delay on task 0 with period 100000
This Message will only display once per session.
Run the Latency Test and resolve before continuing.
3180
3212
Stopping realtime threads
Unloading hal components
13 Feb 2026 20:06 #342910 by tommylight
Replied by tommylight on topic QtPyVCP Mill Touch Screen
@Kell,
Do not send reports asking for help, you will be banned for doing that again.
From your error report:
So did you install QtPyVCP as per the howto on their github?
14 Feb 2026 15:49 #342943 by Lcvette
Replied by Lcvette on topic QtPyVCP Mill Touch Screen
this is a really old ui for qtpyvcp from JT, it may no longer be compatible as it likely did not get updated and tested when we moved to python3 and I think JT has moved on to flexgui, may want o see what he has there if that is your style flavor preference.
Moderators: KCJLcvette
Time to create page: 0.170 seconds
