QtPyVCP Mill Touch Screen
  • BigJohnT
  • BigJohnT's Avatar Topic Author
  • Administrator
  • Administrator
17 Mar 2019 13:12 - 18 Mar 2019 11:24 #128817 by BigJohnT
QtPyVCP Mill Touch Screen was created by BigJohnT
After using my BP_Touch for a while on the mill I decided to change a few things up so I started from scratch and used the new VTK backplot which is way faster to render than gremlin is. Now I'm sort of a minimalist so I don't go for the flashy GUI's but that's all done with stylesheets or in the .qss file so it does not change the GUI to add style if one wants that.
The files
github.com/jethornton/mill_touch
The Docs
jethornton.github.io/mill_touch/index.html
Some screen shots
On this tab I'm using the new container with rules to disable everything in this tab until a tool is loaded
Now with a tool loaded I can set tool offsets for the current tool
JT
Last edit: 18 Mar 2019 11:24 by BigJohnT.
The following user(s) said Thank You: biqut2, chimeno, tommylight, tivoi, KCJ, Leon82, silopolis
  • Moderator
  • Moderator
17 Mar 2019 17:29 #128838 by tommylight
Replied by tommylight on topic QtPyVCP Mill Touch Screen
Elegantly beautiful ! Does it come in black? :)
17 Mar 2019 22:53 #128861 by Leon82
Replied by Leon82 on topic QtPyVCP Mill Touch Screen
Is that the same as the vtk backplot?
I didn't see vcp backplot in the widget list
  • BigJohnT
  • Administrator
  • Administrator
18 Mar 2019 11:22 #128881 by BigJohnT
Replied by BigJohnT on topic QtPyVCP Mill Touch Screen
You can have what ever color you want just change the color in the qss file :)
JT
The following user(s) said Thank You: tivoi
  • BigJohnT
  • Administrator
  • Administrator
18 Mar 2019 11:26 #128882 by BigJohnT
Sorry, that was a typo it is VTK backplot
JT
The following user(s) said Thank You: Leon82
  • BigJohnT
  • Administrator
  • Administrator
18 Mar 2019 14:24 #128901 by BigJohnT
Yes! I changed one word in the config.yml file and copied a dark qss to the ui directory.
JT
The following user(s) said Thank You: chimeno, tommylight, tivoi, emilvv, KCJ
  • Moderator
  • Moderator
18 Mar 2019 21:51 #128925 by tommylight
Yes! I changed one word in the config.yml file ..........
JT
YML file ??? Me thinks you got a german keyboard ! :)
Or is it really an yml file ? I wonder......
Thanks for everything , JT.
  • BigJohnT
  • Administrator
  • Administrator
19 Mar 2019 00:15 #128951 by BigJohnT
JT
Yep it's a .yml file, but don't fret you can also just put a .qss stylesheet in the configuration directory and use it by adding it to the ini file with STYLESHEET = dark.qss. Wow this it getting to be so much fun...
information about .yml files is here qtpyvcp.kcjengr.com/configuration/yml_config.html
JT
The following user(s) said Thank You: tommylight, tivoi
19 Mar 2019 00:42 #128953 by Leon82
How did you get the on screen scale to disappear for the backplot?
  • BigJohnT
  • Administrator
  • Administrator
19 Mar 2019 10:06 #128961 by BigJohnT
You can either toggle them on and off on the settings page or you can set the state you want in the ini file.
qtpyvcp.kcjengr.com/configuration/ini_options.html
JT
The following user(s) said Thank You: emilvv, Leon82
Moderators: KCJLcvette
Time to create page: 0.419 seconds
