QtPyVCP Widget Rules
02 Jan 2020 01:22 - 25 Apr 2020 13:17 #153758
by BigJohnT
QtPyVCP Widget Rules was created by BigJohnT
Widget Rules is a powerful feature of QtPyVCP but can be a bit overwhelming at first so I expanded the QtPyVCP documents with a step by step explanation of widget rules.
www.qtpyvcp.com/widgets/rules.html
If you see anything missing or wrong let me know. I just want users to be able to use the power of Widget Rules.
JT
JT
Last edit: 25 Apr 2020 13:17 by KCJ. Reason: Use new web address in link
02 Jan 2020 23:48 #153840
by Donb9261
Replied by Donb9261 on topic QtPyVCP Widget Rules
Awesome work. Thanks.
03 Jan 2020 17:58 #153914
by Donb9261
In the status:gxxoffset channel tuple the R value is not available. Currently only 9(0-8) values are there. XYZABCUVW.
How hard is it to add the R value? It makes displaying the R value of the current WO index hard to display outside the table.
Thanks. Don
Thanks. Don
03 Jan 2020 23:47 #153932
by BigJohnT
Replied by BigJohnT on topic QtPyVCP Widget Rules
That is not provided by LinuxCNC on that status item. I have no clue where the python module is in LinuxCNC
linuxcnc.org/docs/2.8/html/config/python...xcnc_stat_attributes
JT
JT
05 Jan 2020 12:04 #154092
by Donb9261
Understood. Most likely in the linuxcnc binary files. That said, it would be nearly impossible to change without the source.
05 Jan 2020 13:31 #154097
by BigJohnT
03 Feb 2020 15:02 #156439
by hottabich
Replied by hottabich on topic QtPyVCP Widget Rules
Hello. When adding spindle speed with the slider, the speed in hal show changes, but not in the indicator. Can this be fixed with Widget Rules?
15 Feb 2020 17:11 #157467
by KCJ
Replied by KCJ on topic QtPyVCP Widget Rules
Don, I thing the data you are looking for is available from the `status:rotation_xy` data channel.
15 Feb 2020 17:20 #157468
by KCJ
hottabich, yes, you can do almost anything with rules!
The `status:spindle.0.speed` value is the programmed spindle speed (always matches the value of the last S word in gcode). So to get the actual commanded spindle speed you need to multiply by the spindle override, which is available as `status:spindle.0.override`.
20 Feb 2020 17:02 - 01 Mar 2020 20:30 #158030
by hottabich
Thanks, it works!
Last edit: 01 Mar 2020 20:30 by hottabich.
Time to create page: 0.433 seconds
