QtPyVCP Widget Rules
- strahlensauger
- Thank you received: 66
01 May 2020 13:27 #166310
by strahlensauger
Replied by strahlensauger on topic QtPyVCP Widget Rules
Hello Kurt,
I encountered an error in Probe_screen. If I go to tools and enter a new tool and in the comment I use a german
Umlaut key (Ä), I get an error message and I only can restart the whole program. (Not a big deal, if you know,
but maybe the screen could catch "faulty" characters...)
'ascii' codec can't encode character u'\xe4' in position 6: ordinal not in range(128)
File "/home/joe/qtpyvcp/qtpyvcp/widgets/input_widgets/tool_table.py", line 30, in displayText
return "{}{}".format(self._padding, value)
UnicodeEncodeError: 'ascii' codec can't encode character u'\xe4' in position 6: ordinal not in range(128)
Not an issue but maybe a "user bug"
, when I started using probe_screen I could jog continously, now I only can jog according to the buttons (max 5mm), which is a bit annoying if you want to go long distances and have jog 20 times.
Maybe you know what happened, or how I can easily come back to continous jogging (I could maybe add a button "continous" like in axis...)?
cheers
Joerg
cheers
Joerg
- KCJ
- Thank you received: 267
02 May 2020 13:44 #166403
by KCJ
Replied by KCJ on topic QtPyVCP Widget Rules
Thank you for the bug report!
Unicode should be valid in the tooltable remarks section, I will fix this.
Try adding JOG to the beginning of your jog increments in the INI. This should give you a continuous jog option.
The jog increments widget needs to be reworked to make it more flexible..
Cheers,
Kurt
Cheers,
Kurt
The following user(s) said Thank You: strahlensauger
- strahlensauger
02 May 2020 19:58 #166423
by strahlensauger
That was easy - if you know... Now I can jog around again...
If error messages pop up I'll keep you informed.
You still have the YAML file for configuring keys in mind?
Thanks again
Thanks again
Moderators: KCJ, Lcvette
Time to create page: 0.328 seconds
