Fusion360 Postprozessor für LinuxCNC 5 Achsen
7 years 10 months ago #122103 by Hakan
Perhaps expressed from my frustration during the short test I made. It isn't that hard, I agree. But as soon as the A axis had an angle, for example jogging in Z meant I got motion in Z, Y and A. I wasn't used to that and found it a bit surprising, but understandable after a bit of thinking. I think it is really good to be able to switch between the modes.
If one is comfortable with this, tcp is the easiest way to get g-code support from Fusion 360, just a few lines to change that reflects the 4 and 5 axis config.
7 years 4 months ago - 7 years 4 months ago #136460 by plopes9000
Here's my version of linuxcnc XYZAC post processor for Fusion 360. Its based on tecno inverse time feed, Spangled 20190223 enable G64 path blending and also some code I stole from another post processor to Rewind C Axis since my setup is -10,+110 degrees in C.
if (true) { // note: setup your machine here var aAxis = createAxis({coordinate:0, table:true, axis:[-1, 0, 0], offset:[0, 0, 0], cyclic:false, range:[-10,110], preference:0}); var cAxis = createAxis({coordinate:2, table:true, axis:[0, 0, -1], offset:[0, 0.15, 0], cyclic:false, range:[-360000,360000], preference:0}); machineConfiguration = new MachineConfiguration(aAxis, cAxis); setMachineConfiguration(machineConfiguration); //optimizeMachineAngles2(0); // TCP mode enabled (eg. M128, TRAORI, G43.4, G243) optimizeMachineAngles2(1); // TCP mode disable (eg. M128, TRAORI, G43.4, G243) }
See also videos of my 4/5 Axis Build and Test Run - youtube link
Last edit: 7 years 4 months ago by plopes9000.
The following user(s) said Thank You: andypugh
7 years 4 months ago #136463 by pl7i92
nice all axis videos show only the Iso cordinate flat system movements
no 5Axis syncron mode
will it be implemented in the post ?
7 years 4 months ago #136464 by andypugh
Nice. I can see myself offering-up my spare harmonic drive mounting casting to my existing A axis tonight, and seeing if there are any more FHA drives on eBay.
7 years 4 months ago - 7 years 4 months ago #136467 by plopes9000
Yes the post will handle 5 simultaneous axis just fine as will the machine. But I do have issues with the toolpaths generated by Fusion360 ... they are not clean - nothing to do with the post processor or machine. In the last video - part 5, the curved section is actually a Flow op so 5 axis simultaneous - I even made the remark that the toolpath is not clean. Also the op before the last of the same video - part 5 - is a simultaneous 5 axis op.
7 years 4 months ago #136468 by plopes9000
Thanks Andy - quite happy. Yes the FHA are like a perfect fit for 4th and 5th Axis.
Moderators: Muecke
