wo ist die datei firmware.py.
- Andreas_Rackow
4 years 9 months ago #230722
by Andreas_Rackow
Replied by Andreas_Rackow on topic wo ist die datei firmware.py.
Configuration Name: HOSTMOT2
BoardName : MESA5I25
FPGA Size: 9 KGates
FPGA Pins: 144
Number of IO Ports: 2
Width of one I/O port: 17
Clock Low frequency: 33.3333 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
ClockFrequency: 33.333 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: IOPort
There are 2 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: QCount
There are 4 of QCount in configuration
Version: 2
Registers: 5
BaseAddress: 3000
Module: StepGen
There are 4 of StepGen in configuration
Version: 2
Registers: 10
BaseAddress: 2000
Module: PWM
There are 1 of PWM in configuration
Version: 0
Registers: 5
BaseAddress: 4100
ClockFrequency: 200.000 MHz
Module: SSerial
There are 1 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5B00
Instance Stride: 64 bytes
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for P3
Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir
1 0 IOPort None
14 1 IOPort PWM 0 PWM (Out)
2 2 IOPort StepGen 0 Step/Table1 (Out)
15 3 IOPort None
3 4 IOPort StepGen 0 Dir/Table2 (Out)
16 5 IOPort None
4 6 IOPort StepGen 1 Step/Table1 (Out)
17 7 IOPort None
5 8 IOPort StepGen 1 Dir/Table2 (Out)
6 9 IOPort StepGen 2 Step/Table1 (Out)
7 10 IOPort StepGen 2 Dir/Table2 (Out)
8 11 IOPort StepGen 3 Step/Table1 (Out)
9 12 IOPort StepGen 3 Dir/Table2 (Out)
10 13 IOPort None
11 14 IOPort QCount 0 Quad-A (In)
12 15 IOPort QCount 0 Quad-B (In)
13 16 IOPort QCount 0 Quad-IDX (In)
IO Connections for P2
1 17 IOPort None
14 18 IOPort None
2 19 IOPort None
15 20 IOPort QCount 1 Quad-A (In)
3 21 IOPort QCount 1 Quad-B (In)
16 22 IOPort QCount 1 Quad-IDX (In)
4 23 IOPort QCount 2 Quad-A (In)
17 24 IOPort QCount 2 Quad-B (In)
5 25 IOPort QCount 2 Quad-IDX (In)
6 26 IOPort QCount 3 Quad-A (In)
7 27 IOPort QCount 3 Quad-B (In)
8 28 IOPort QCount 3 Quad-IDX (In)
9 29 IOPort None
10 30 IOPort None
11 31 IOPort None
12 32 IOPort SSerial 0 TXData0 (Out)
13 33 IOPort SSerial 0 RXData0 (In)
Das sagt readhmid
Andreas
FPGA Size: 9 KGates
FPGA Pins: 144
IDROM Type: 3
Module: WatchDog
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
Version: 0
Registers: 5
BaseAddress: 1000
Module: QCount
Version: 2
Registers: 5
BaseAddress: 3000
Module: StepGen
Version: 2
Registers: 10
BaseAddress: 2000
Module: PWM
Version: 0
Registers: 5
BaseAddress: 4100
Module: SSerial
Version: 0
Registers: 6
BaseAddress: 5B00
Module: LED
Version: 0
Registers: 1
BaseAddress: 0200
1 0 IOPort None
15 3 IOPort None
16 5 IOPort None
17 7 IOPort None
10 13 IOPort None
1 17 IOPort None
14 18 IOPort None
2 19 IOPort None
9 29 IOPort None
10 30 IOPort None
11 31 IOPort None
Das sagt readhmid
Andreas
- Thank you received: 7491
4 years 9 months ago #230729
Replied by tommylight on topic wo ist die datei firmware.py.
Das ist ales in ordnung, da sind 4 stpgen, 4 encoder und ein PWM.
- Andreas_Rackow
4 years 9 months ago #230798
by Andreas_Rackow
Schön, dass du das auch so siehst. Ich fang mal an eine HAL zu schreiben.
Was für ein anderes Board könnte ich nehmen, um zumindest eine Anfangskonfiguration zu haben?
- Andreas_Rackow
4 years 9 months ago #230893
by Andreas_Rackow
Problem gelöst.
danke
danke
Moderators: Muecke
Time to create page: 0.342 seconds
