- Thank you received: 8
Laser PWM und entsprechend.hal verändern
- tracer
4 years 8 months ago - 4 years 8 months ago #235148
by tracer
Replied by tracer on topic Laser PWM und entsprechend.hal verändern
Hello PCW,
step by step im coming forward.
in the Hal Config by running the programm the laser_pwn_enable is turning on.
MANY MANY THX to you!!!
I was running the GCode from FRankenlab and also the Laser_PWM_value is changing by the value in GCode Q150 or Q0,2
But i get no PWM Signal at the wirng to the laser.
I connected the Signal PWM wire to TB3 Pin3 and TB3 Pin 5 on the Mesa 7i76e
forum.linuxcnc.org/42-deutsch/44933-lase...aendern?start=0#none
What am i doing wrong?
EDIT
Found the Mistake. I havent hared the Ground from LAser Power Supply to MESA GND:
Now its working. Many Thx to you PCW!!!!!
EDIT
Last edit: 4 years 8 months ago by tracer.
- tracer
4 years 8 months ago #235192
by tracer
I have one issue. If the Laser is in Idle Power 0 and i close Linuxcnc, the Laser goes Full power. Maybe the Mesa card switches.
HOw is it possible to chance this?
- Thank you received: 5334
4 years 8 months ago #235197
Replied by PCW on topic Laser PWM und entsprechend.hal verändern
This should be fixable with 2 changes
1. Use the opposite polarity output from the 7I76E card
2. Invert the PWM in the hal file:
setp hm2_7i76e.0.pwmgen.00.out0.invert_output true
Moderators: Muecke
Time to create page: 2.412 seconds
