stepgen.03.maxvel is too big for current step timings & position-scale, Clipping
2 years 11 months ago #285920 by PCW
Yes, that reduction drive does not look appropriate for a linear axis
2 years 11 months ago #285924 by Muecke
What does the reduction drive?
I need more strength.
This axle turns a car wheel, it doesn't have to run fast but it would be nice to run a little faster than now.
Picture, the motor with dribble is on the back, I don't have another picture right now.
Calculation:
Corner of travel: 360 mm / revolution
microsteps 1/2 =400 steps per revolution
reduction 40/1 = 16000 steps per revolution
360 mm = 16,000 Steps
1 mm = (1*16,000) / 360 mm
1 mm = 44,4444444 Steps / mm
Why is the calculation wrong?
yes LinuxCNC would like to have a linear axis for the Y axis, but this is round ;-)
2 years 11 months ago #285925 by tommylight
Of what?
Nothing in that picture has a perimeter of 360mm.
what diameter shaft?
what wheel size?
what tire size?
Do you want to scale it to shaft or to wheel?
2 years 11 months ago #285930 by Muecke
I used 360mm because that is the number of degrees of a circle ;-)
The shaft A has a diameter of 5cm (I think, I have to measure it).
The tyre can have a diameter of 40cm to approx. 110cm.
If you ask like that, I would do the dimensioning based on the shaft.
I have tested by hand a speed of about 7mm/second when I want to rotate the tyre under load.
It would be good if I could move the shaft at 7mm/second under load, more than that in rapid traverse.
At the moment I doubt that I can achieve these speeds with this gearbox.
2 years 11 months ago #285934 by tommylight
That makes sense only for a 114.594938724 mm shaft diameter.
For 50mm shaft
50x3.1415=157.075mm for one rotation.
2 years 11 months ago #285937 by Muecke
Then this is the new calculation.
Calculation:
Corner of travel: 157.075 mm / revolution
157.075 mm = 16,000 Steps
1 mm = (1*16,000) / 157.075 mm
1 mm = 101,862168 Steps / mm
New value
SCALE = 101.862168
I will test it
Moderators: Muecke
Time to create page: 0.325 seconds
