Erklärung Ethercat
26 Jan 2025 15:17 - 26 Jan 2025 20:27 #319891 by Hakan
Replied by Hakan on topic Erklärung Ethercat
You modify cia402.0.pos-scale. It should be "increments per machine unit".
rodw mentioned earlier in the thread how to calculate it.
For example if the servo encoder has 4000 increments per revolution and the ball screw pitch is 5mm, you enter 4000/5 = 800 increments/mm.
That's close to line 50 in the cia402.hal file.
setp cia402.0.pos-scale 800
Last edit: 26 Jan 2025 20:27 by Hakan. Reason: typo
The following user(s) said Thank You: rodw, Red_D85
28 Jan 2025 18:36 #320006 by Red_D85
Replied by Red_D85 on topic Erklärung Ethercat
Das funkioniert. Ich weis nur nicht wieso ich bei einer encoderauflösung statt 1000, 10000 einstellen muss aber dann stimmt es.
Danke an alle
That works. I dont know why i have to set 10000 per revolution? Correct would be 1000 per revolution. But with 10k it works.
Thank you all
Moderators: Muecke
Time to create page: 0.116 seconds
