Config-Problem Ethercat
1 year 3 weeks ago #335995 by Red_D85
Replied by Red_D85 on topic Config-Problem Ethercat
Yes thats ok
But i can not link joint.2.motor-pos-fb to cia402.2.pos-fb
Because it is already linked :net z-pos-cmd joint.2.motor-pos-cmd cia402.pos-cmd joint.2.motor-pos-fb
Axis and halshow means that move the axis but it dosnt move.
1 year 3 weeks ago - 1 year 3 weeks ago #336007 by Hakan
Replied by Hakan on topic Config-Problem Ethercat
Can you check that the drive is in OP like below
And with halshow that you have the same values in the following parameters,
not the commanded and actual positions of course, but they should follow the same pattern.
For your Z drive.
Last edit: 1 year 3 weeks ago by Hakan.
1 year 3 weeks ago #336076 by Red_D85
here my screenshoots:
Thanks for your help
1 year 3 weeks ago #336077 by Hakan
Also check opmode-display and connect it to cia402
like here  github.com/dbraun1981/hal-cia402/blob/ma...le/ethercat-conf.xml and here  github.com/dbraun1981/hal-cia402/blob/main/example/cia402.hal
If it still doesn't work after that, you should do a factory reset of the erc60.
It means writing to a SDO with "ethercat download -p 5 0x2nnn m 1"
where you need to find the right index n and subindex m from the erc60 manual.
1 year 3 weeks ago #336086 by Red_D85
Strang. minimal config works without problems.:
File Name: ethercat-c...imal.xml
File Size:1.38 KB
File Name: cia402_minimal.hal
File Size:2.3 KB
 full setup, sometimes it works, sometimes it doesn't image missing /media/kunena/emoticons/sad.png
File Name: ethercat-c...0-08.xml
File Size:4.86 KB
File Name: cia402_2025-10-08.hal
File Size:4.43 KB
is the problem because "dcconf"?
1 year 3 weeks ago #336143 by Hakan
Yes, I see the difference in refclocksynccycles and assignActivate, that's most likely it.
I seem to recall the erc60 only works with DC sync mode, that is set assignActivate=300.
Moderators: Muecke
Time to create page: 0.060 seconds
